Cisco ACI APIC Controller Connectivity Test
OBD
Hi all,
 I know that our APICs use out-of-band interface for external connections.  But I want to check whether our controllers reach a website from internet.  Unfortunately there is no telnet commands  in APIC and leaf switches even in bash.   How can I verify connectivity ?
Thank you
Sergiu.Daniluk
HI @OBD
curl might be the best and easy way to verify connectivity with a website:
admin@apic1:~> curl -Is http://www.google.com | head -n 1
HTTP/1.1 200 OK
Cheers,
Sergiu
Sergiu.Daniluk
HI @OBD
HTTP/1.1 200 OK
Cheers,
Sergiu
OBD
Thank you for your reply. It has worked for me
