Cisco ACI Multipod issues
Sean Pillay
Guys
We are having multipod issues, in and EPG if have 2 routers on POD A as a static path they can communicate with each other, however when  I have move router B to POD B and change the static path in the EPG they cannot communicate, does any have a similar experience ? Same issue with port channeling the routers with VPC in different pods. In the same POD they can always communicate
We also have DVS with ESX servers setup between PODS and we can V motion hosts from one pod to another pod. At least that works
6 Replies 6
Marcel Zehnder
Hi Sean
Sounds like a multicast issue in the IPN.
1.) For the EPG not working, check the Multicast-Group for the corresponding Bridge Domain:
moquery -c fvBD -f 'fv.BD.name=="<BD-NAME-HERE>"' | grep bcastP
2.) Check the mroute-table for the resulting mulitcast group on all of your IPN-devices
How did you configure your IPN? Is it a single area connected to the spines or do you use a separate area to attach the spines?
Marcel
We have 4 IPNs, 2 in POD A and 2 in POD B.
OSPF AREA 0.0.0.0 to the spines
Command output as requested
moquery -c fvBD -f 'fv.BD.name=="BD-Internet-Pub"' | grep bcastP
bcastP : 225.0.56.0
225.0.56.0 appears on 3 of the IPNS
IPN1-PODA
(*, 225.0.56.0/32), bidir, uptime: 03:06:20, ip pim igmp
Incoming interface: loopback1, RPF nbr: 10.36.119.1, uptime: 03:06:20
Outgoing interface list: (count: 1)
Ethernet1/49.4, uptime: 02:59:57, igmp
IPN2-PODA
(*, 225.0.56.0/32), bidir, uptime: 02:32:46, pim ip
Incoming interface: loopback1, RPF nbr: 10.36.119.1, uptime: 02:32:46
Ethernet1/2, uptime: 02:32:46, pim
IPN3-PODB
(*, 225.0.56.0/32), bidir, uptime: 02:33:59, igmp ip pim
Incoming interface: Ethernet1/2, RPF nbr: 10.36.119.41, uptime: 02:33:59
Outgoing interface list: (count: 2)
Ethernet1/2, uptime: 02:33:59, pim, (RPF)
Ethernet1/49.4, uptime: 02:33:59, igmp
IPN4-PODB
NO ENTRY
Sean
From all your IPNs could you please post "show cdp neighbor" and "show ip route <SHADOW-RP-IP>"?
Marcel
As requested
IPN-1# sh cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
ACI-OOB-SW01 mgmt0 155 R S I WS-C2960XR-48 Gig1/0/13
RDV-IPN-3(F71Z)
Eth1/1 152 R S s N9K-C93180YC- Eth1/1
RDV-IPN-4(FDT3)
Eth1/2 139 R S s N9K-C93180YC- Eth1/1
1DP-IPN-2(FD3)
Eth1/3 139 R S s N9K-C93180YC- Eth1/3
IPN-1# sh ip route vrf fabric-mpod 10.36.119.1
IP Route Table for VRF "fabric-mpod"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
10.36.119.1/32, ubest/mbest: 2/0, attached
*via 10.36.119.1, Lo1, [0/0], 3w0d, local
*via 10.36.119.1, Lo1, [0/0], 3w0d, direct
IPN-2# show cdp neighbors
ACI-OOB-SW01 mgmt0 137 R S I WS-C2960XR-48 Gig1/0/14
RDV-IPN-3(FD1Z)
Eth1/1 120 R S s N9K-C93180YC- Eth1/2
RDV-IPN-4(FD3)
Eth1/2 167 R S s N9K-C93180YC- Eth1/2
1DP-IPN-1(FDO2032123L)
Eth1/3 167 R S s N9K-C93180YC- Eth1/3
Total entries displayed: 4
IPN-2# sh ip route vrf fabric-mpod 10.36.119.1
IPN-3# show cdp neighbors
ACI-OOB-SW01 mgmt0 145 R S I WS-C2960XR-48 Gig1/0/22
1DP-IPN-1(FD3L)
Eth1/1 138 R S s N9K-C93180YC- Eth1/1
1DP-IPN-2(FD03)
Eth1/2 138 R S s N9K-C93180YC- Eth1/1
RDV-IPN-4(FDOT3)
Eth1/3 178 R S s N9K-C93180YC- Eth1/3
*via 10.36.119.17, Eth1/1, [110/5], 3w0d, ospf-ACI, intra
*via 10.36.119.37, Eth1/2, [110/5], 3w0d, ospf-ACI, intra
IPN-4# show cdp neighbors
ACI-OOB-SW01 mgmt0 133 R S I WS-C2960XR-48 Gig1/0/21
1DP-IPN-1(FD3L)
Eth1/1 155 R S s N9K-C93180YC- Eth1/2
1DP-IPN-2(FD3)
Eth1/2 155 R S s N9K-C93180YC- Eth1/2
RDV-IPN-3(FDZ)
Eth1/3 147 R S s N9K-C93180YC- Eth1/3
IPN-4# sh ip route vrf fabric-mpod 10.36.119.1
*via 10.36.119.21, Eth1/1, [110/5], 3w0d, ospf-ACI, intra
*via 10.36.119.41, Eth1/2, [110/5], 3w0d, ospf-ACI, intra
Looks like your phantom-RP configuration is incorrect:
IPN1 and IPN2 need different masks for the Lo1 interface.
See the following document:
https://supportforums.cisco.com/document/55696/rp-redundancy-pim-bidir-phantom-rp
Marcel
And also pay attention to the remarks in the document above:
    * It's important the RP address is NOT the loopback address but one of the other address in the subnet defined on the loopback
    * By default, OSPF advertises all loopbacks as /32 so the need of 'ip ospf network point-to-point' command to advertise the subnet mask
