01-25-2022 12:55 AM - edited 01-25-2022 12:56 AM
We have some issues with end point update.
We have a multi pod architecture with 3 pods.
When I move an EP from POD2 to POD1, the POD1 leaf can see the new EP but the POD2 leafs are not updating.
I suspect a COOP issue, and i see this error on COOP protocol on the POD2 Spines :
Operationnal state : initializing
Operationnal state qualifier : Configuration not resolved
We don't have any coop issue on POD1 et POD3, only on POD2
Is there a way to go deeper , reset COOP , restart something ?
I'm not an expert for COOP management
Thanks a lot
Maxime
Solved! Go to Solution.
01-25-2022 06:01 AM - edited 02-02-2022 10:26 PM
For some reasons, it looks like "MPOD-CONFIGURED" flag is missing from the POD2.
Did any multi-pod related config changed?
First of all, although I was not able to find any external bugs related to this issue, I would suggest you open a TAC case.
If that is not an option, for whatever reasons, or you can do it but after you resolve first the problem, I would suggest you collect show tech-support files from all the spines & APICs.
Second of all, what I would do to try and recover from this state would be in this order:
1. Reload Spine201 - this is the COOP master
2. If not resolved, reload Spine202
3. If not resolved, clean reload of one spine at a time ("setup-clean-config.sh" + "reload" commands in CLI)
Hope this will solve your problem.
Stay safe,
Sergiu
02-01-2022 12:00 AM
Hi all
An update on this case.
The coop database seems ok now. I've reloaded the 2 POD spines and now MPOD-CONFIGURED flag is now present and I haven't any errors anymore.
When I move ands EP from POD to POD1 everything seems ok, POD1 leaf update and see the EP as local and POD2 bounce and see the EP through the tunnel.
01-25-2022 01:41 AM
Is this a new setup? Was it working before? What version do you run in your fabric? Do you have the BGP RR configured?
Sergiu
01-25-2022 01:54 AM - edited 01-25-2022 01:57 AM
01-25-2022 02:46 AM
01-25-2022 03:22 AM
We have 2 spines in POD2 :
First one :
S201# show coop internal info global
System info:
Local Adjacency (Pythia)
Flags status: f9 or_cfg: 1 ,
L2RIB Sharding status : L2RIB Sharding status : L2RIB Sharding status : L2RIB Sharding status : Addr : 10.192.16.64
Identity : 0.0.0.0
HelloIntvl : 0
Operational St: 0
Last Contact : 0
Primary Key : 44274
Flags : 0x0
Shard Info:
Master Itvl [0x7fffffff, 0xffffffff]
Backup Itvl [0x0, 0x7ffffffe]
L2RIB MPOD Shard Itvl [0x7fffffff, 0xffffffff]
Minimum supported version : 1
Maximum supported version : 2
Running version : 2
Connection Mode : Compatible
Citizen Prefix : 10.192.0.0/16
Potential Upgradeable Version : 2
Last Citizen Lower Version TS : N/A
Last Citizen Lower Address : None
Time To Next Upgrade : 0 seconds
Max value of the minimum version advertised by all oracles : 1
ISIS Fabric Link State : UP
vpod-vSpine: 0, vpod-vTor 0, vpod_vPodId 2
vspine_hrep_alloc_allowed: No
vpod_subnet_count 0
vpod_mcast_hrep active count 0
Oracle Adjacency (Dodona)
Addr : 10.192.16.65
Identity : 0.0.0.0
HelloIntvl : 60
Operational St: 2
Last Contact : 1643109452
Primary Key : 45184
Flags : 0x0
Oracle Status : UP-ACTIVE , , , ,
Flags status: 5fbf or_cfg: 17 Illegal Pings: 0
Shard Info:
Master Itvl [0x0, 0x7ffffffe]
Backup Itvl [0x7fffffff, 0xffffffff]
L2RIB MPOD Shard Itvl [0x0, 0x7ffffffe]
Running version : 2
Non-secure TCP connected : Y
Secure TCP connected : Y
Secure CZ TX TCP connected : N
Non-secure TCP accepted : Y
Secure TCP accepted : Y
Secure CZ TX TCP accepted : N
Non-secure TCP ACTIVE : N
Secure TCP ACTIVE : Y
Second one :
S202# show coop internal info global
System info:
Local Adjacency (Dodona)
Flags status: f9 or_cfg: 0 ,
L2RIB Sharding status : L2RIB Sharding status : L2RIB Sharding status : L2RIB Sharding status : Addr : 10.192.16.65
Identity : 0.0.0.0
HelloIntvl : 0
Operational St: 0
Last Contact : 0
Primary Key : 44473
Flags : 0x0
Shard Info:
Running version : 2
vpod_subnet_count 0
Oracle Adjacency (Pythia)
Addr : 10.192.16.64
Identity : 0.0.0.0
HelloIntvl : 60
Operational St: 2
Last Contact : 1643109752
Primary Key : 45632
Flags : 0x0
Flags status: 5fbf or_cfg: 15 Illegal Pings: 0
Shard Info:
Running version : 2
01-25-2022 03:33 AM
and we have some difference with the POD1 , where we have no issues ...
S101# show coop internal info global
System info:
L2RIB Sharding status : MPOD-CONFIGUREDL2RIB Sharding status : L2RIB Sharding status : L2RIB Sharding status : Addr : 10.191.152.65
Identity : 0.0.0.0
HelloIntvl : 0
Operational St: 0
Last Contact : 0
Primary Key : 44318
Flags : 0x0
Shard Info:
Running version : 2
Citizen Prefix : 10.191.0.0/16
vpod-vSpine: 0, vpod-vTor 0, vpod_vPodId 1
vpod_subnet_count 0
Addr : 10.191.152.64
Identity : 0.0.0.0
HelloIntvl : 60
Operational St: 2
Last Contact : 1643109592
Primary Key : 45466
Flags : 0x0
Oracle Status : UP-ACTIVE , MPOD-CONFIGURED, , ,
Flags status: 7fbf or_cfg: 15 Illegal Pings: 0
Shard Info:
Running version : 2
Non-secure TCP ACTIVE : Y
Stay safe,
Sergiu
01-25-2022 06:47 AM
multipod config didn't change
reload is planned on thursday morning ( need to plan it during some specific periods here)
I will update this post after that
If reload don't resolve the issue i will open a TAC case.
Thanks for your help
Maxime
01-25-2022 07:19 AM
Make sure you collect the show tech files. Do them as fast as possible (now?) to avoid loosing any critical data/logs.
Keep us updated with the results!
Sergiu
02-01-2022 12:00 AM
Hi all
