12-15-2022 02:12 AM
Does anyone know if its possible to use the CVR-QSFP28-SFP25G for the N9K-C9336C-FX2 to do 10Gb connections or do I need to use the CVR-QSFP-SFP10G= ?
12-15-2022 02:44 AM
if you have 10/25 GB SFP you can do, if you have only 10GB SFP i would suggest to go CVR-QSFP-SFP10G=
12-15-2022 02:47 AM
Thanks Balaji, will it work with just 10gb or is the CVR-QSFP-SFP10G= as its cheaper ?
12-17-2022 12:40 AM
yes it's viable both point of view (Compatability and cost)
12-15-2022 05:10 AM
As stated in the other thread, that transceiver is not yet supported on that platform - it will NOT work at 25G, 10G or any speed with the released versions as of today. Support is coming mid next year.
Robert
12-17-2022 12:22 AM
if you want to achieve 10G connectivity on N9k-C9336C-FX2, CVR-QSFP-SFP10G (with an SFP-10G) is supported according to Cisco Compatibility Matrix.
But your switch needs to meet the minimum OS version, either as an NX-OS or an ACI-based switch.
04-10-2023 12:51 PM
Is the cvr-qsfp28-sfp25g coming this year
04-10-2023 01:32 PM
Yes CVR-QSFP28-SFP25G support will come in the next NXOS 10.3(3)F release due out this month/early next with support on the 93108TC-FX3P, 9348GC-FXP, 9336C-FX2 and GX2 platforms.
Robert
05-04-2023 12:35 PM
Any update to the release. I really need for the cvr to work with my c9336C-FX2. Equipment only goes up to 25GB and currently needing to burn additional switches for support for them and then tying into the nexus
Brian
05-04-2023 03:35 PM
07-12-2024 02:06 AM
Hi Robert,
Trying to find spec sheet of this adaptor however I cannot find it anywhere, any idea where to look for it ?
best regards
07-27-2023 11:44 AM
Do you know if the CVR-QSFP28-SFP25G will be supported in the C9500-48Y4C switches as well?
11-30-2023 12:29 PM - edited 11-30-2023 12:32 PM
I'm running 10.3.3.F on my C9336-FX2 anyone connecting 25GB with a C9300-48P? Which CVR/model was chosen?
11-30-2023 11:40 PM
C9300-48P - what uplink Module - check the datasheet
C9300-NM-2Y
Catalyst 9300 Series 2x 25G/10G/1G Network Module
