Deploying EPG on a leaf port.
Ramu Gajula
Hello Experts,
I am trying to deploy an EPG on a leaf port where an N5K1 is connected. I have performed this task and i have deployed the same EPG on a  leaf port where another layer-3 switch is connected. for both the ports i have used same encapsulation Vlan and created SVI's on both the switches.
The issue is i am unable to communicate between both the switches even though they are in same EPG. please help me if i am missing something here.
2 Accepted Solutions
All is working now:
N5K-1# ping 192.168.1.254
PING 192.168.1.254 (192.168.1.254): 56 data bytes
Request 0 timed out
64 bytes from 192.168.1.254: icmp_seq=1 ttl=62 time=0.676 ms
64 bytes from 192.168.1.254: icmp_seq=2 ttl=62 time=0.489 ms
64 bytes from 192.168.1.254: icmp_seq=3 ttl=62 time=0.476 ms
64 bytes from 192.168.1.254: icmp_seq=4 ttl=62 time=0.475 ms
--- 192.168.1.254 ping statistics ---
5 packets transmitted, 4 packets received, 20.00% packet loss
round-trip min/avg/max = 0.475/0.529/0.676 ms
PING 192.168.1.2 (192.168.1.2): 56 data bytes
Request 0 timed out
64 bytes from 192.168.1.2: icmp_seq=1 ttl=254 time=1.155 ms
64 bytes from 192.168.1.2: icmp_seq=2 ttl=254 time=0.623 ms
64 bytes from 192.168.1.2: icmp_seq=3 ttl=254 time=0.617 ms
64 bytes from 192.168.1.2: icmp_seq=4 ttl=254 time=0.614 ms
--- 192.168.1.2 ping statistics ---
round-trip min/avg/max = 0.614/0.752/1.155 ms
Summary of Issue:
  • You needed to created an interface profile for the switch interfaces
  • You needed to create a vlan pool, aaep, and L2 Bridged Domain
  • You needed to Create a VRF, BD, and associate the EPG to the BD
  • You then needed to assoc. the L2 Domain to the EPG
  • Configure VLAN Trunk ports on the connections to N5K and N3K
L2 Bridging working
Expand the interface selector
-> Access Port Selector
Modify interfaces to 1/4-5  or simply add another interface 1/5
T.
15 Replies 15
Tomas de Leon
Ramu,
Thank you for using the ACI Cisco Support Community!  For this question and your future questions, please provide a summary of the issue or problem.  Then provide more detailed information in regards to your configuration.
For example, from the information that you provided, we are just guessing on what possibly be the issue.
Some upfront information would be helpful:
  • Are you using Static Bindings (Paths) on the EPG?
  • What ACI firmware version are you running? (Assumption is that you are running 1.2(1i) or later)
  • Please provide the output from the APIC CLI command "show epg <epg_name> detail".  Substitute your EPG Name with issue for <epg_name>.
  • Please provide the output from the APIC CLI command "show bridge-domain <bd_name> detail". Substitute your BD Name (associated with EPG) with issue for <bd_name>.  Note: Since you are extending the L2 domain, the BD configuration should be configured to "flood",
  • Please provide "show lldp neighbors" from the leaf(s) and externally connected switches.
  • What are the intended VLANs to Trunk?
  • Are the connections single interface connections or VPC's?
  • Is physical layer up on the connections between Leaf(s) ports and External Switches?
  • Are there any faults on the EPG?  If so, please provide the detailed information regarding those faults.
Once we get some of the information listed above, we can better ascertain the issue.
Cheers!
T.
Hi Tomas,
Sure, I'll follow that. Thank you. Please find my answers below.
Yes, I am using static bindings.  referring to below document.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Deploying_EPG_on_Specific_Port.html
I am using 1.0(3f).
I get the below output after executing that command
admin@apic1:WEB> show epg WEB
Unknow scope: epg WEB
admin@apic1:WEB>
I haven't created any BD, as my idea is deploy EPG on two leaf ports where switches are connected and make them communicate. not extending any L2 domain.
Leaf1# show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
apic1 Eth1/1 120 58:f3:9c:24:2e:67
apic2 Eth1/2 120 58:f3:9c:24:30:6f
apic3 Eth1/3 120 58:f3:9c:24:33:c9
switch Eth1/4 120 B Eth1/1
switch Eth1/5 120 B Eth1/2
switch Eth1/7 120 BR Eth1/1
Spine1 Eth1/49 120 BR Eth1/1
Spine2 Eth1/50 120 BR Eth2/1
Total entries displayed: 8
Switches are connected on leaf1 ports 1/4&1/7
intended to use only one Vlan 200 and configured it as encap vlan-200 on both the ports.
Single interface connections.
Yes.
None.
Please let me know if you need any other data.
Since you are running 1.0, the APIC CLI commands will not work.  The iNXOS CLI commands introduced in 1.2.   So, please paste a screen shot from the static bindings screen of the EPG.
T.
Hi Tomas,
Please find the attached screen shot of static bindings of EPG WEB.
Ramu,
You are trying to setup a "Trunk" to your external switches so you need to configure MODE "Tagged".  You have untagged right now.
T.
Hi Tomas,
I was using access mode on my end switches thinking that  the frames will go untagged and so i configured untagged on EPG binding. However, i changed it to tagged and trunk mode on my switches, but i am not able to ping. i am not sure what i am missing here. please find the attached screen shot and below  config from end switches.
Config from N5K-1:
interface Ethernet1/1
switchport mode trunk
N5K-1# sh run int vlan 200
!Command: show running-config interface Vlan200
!Time: Tue Jun 15 04:59:13 2010
version 5.2(1)N1(4)
interface Vlan200
no shutdown
ip address 192.168.1.1/24
Config from N3K:
N3K# sh run int vlan 200
!Time: Tue Jan 5 05:02:46 2016
version 5.0(3)U3(2b)
interface Vlan200
no shutdown
ip address 192.168.1.2/24
N3K# ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 192.168.1.1 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
For each interface on each External Switch you need:
switchport trunk allow vlan 200
Also, as I mentioned above.. Is flooding configured on the BD?
The EPG is associated with a BD.  Once you configure a BD and associate the EPG to the BD and configure the external switches to allow vlan 200, things shoould work as expected.
Cheers!
T.
Hi Tomas,
Yes, I have enabled the flooding on the BD. Please find the screen shot attached.
Config on N3K:
N3K# sh run int eth1/1
!Command: show running-config interface Ethernet1/1
!Time: Wed Jan 6 08:09:17 2016
switchport trunk allowed vlan 200
Config on N5K1:
!Time: Wed Jun 16 08:07:18 2010
version 5.2(1)N1(4)
interface Vlan200
no shutdown
What else i might be missing? Do i have to create a Private network as well? I thought BD and Private network are not needed.
Yes a VRF is needed.
Tenant-> VRF-> BD -> AP-> EPG
You may want to look at the ACI Fundamentals Guide:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/aci-fundamentals/b_ACI-Fundamentals/b_ACI_Fundamentals_BigBook_preface_01101.html
Also, take a look at some of the Cisco Live Presentations and since you are internal, you have a valuable resource in the ACI Techzone Forum.
Cheers!
T.
Hi Tomas,
Thank you.
I have upgraded my firmware from 1.0(3f) to 1.1(2k).
Now i have created VRF--BD--EPG however, I am unable to ping.
one more thing. I guess i don't have to use AEP to deploy vlan on leaf port as i am doing it through static binding . please correct me if i am wrong.
Ramu.
attaching another output.
All is working now:
Request 0 timed out
Request 0 timed out
Summary of Issue:
L2 Bridging working
Hi Tomas,
I have configured the steps and the ping started working.
Step1: Created the vlan pool.
Step2:Created external bridge domain and associated it with the vlan pool created.
Step3: Created AEP and mapped it to the bridge domain.
Step4: Created the below switch profile following with interface profile, interface selector and interface policy.
Switch profile [l2-domain-sp1]----àInterface profile [l2-domain-intselector1]---à Interface selector [l2-domain-intsel] (I have selected  1/4, 1/7   as they belong to same node) ---à Interface policyGroup [l2-domain-IntPolGrp].
Step5: statically bind the interfaces to the EPG.
I have another idea of adding  my N5K2 which is connected to  leaf1 port 1/5 to EPG. So, All I have to do is edit the interface selector and add 1/5 in it and  bind the interface to EPG statically. So that I don’t have to create all the policies again.
But the problem I am facing is, I cannot edit the interface  profile and add 1/5 to interface selector. Do we have such option ?
Ramu.
T.
