05-24-2015 09:50 AM - edited 03-01-2019 04:50 AM
Hi everyone,
I have some questions,
1. What is a difference between Subnets in EPG and Subnets in BD?
2. How many Subnets(in 1 Bridge Domain) can I create in tenant Common?
tienbui
05-24-2015 06:48 PM
Hello
regarding question 1) no real difference in where the subnet is defined. Under the EPG it is expected that the subnet will be used for shared services like route leaking for inter-tenant communications
as per the number of subsets in 1 BD under tenant common, I would have to check internally or recreate to find out.
Ill report back back here with my findings! Thanks for using support forums!
05-25-2015 06:28 AM
The only other consideration on whether a subnet should be defined at the BD vs. EPG level is in regards to route advertising. If you have a L3 external peering via OSP/EIGRP/BGP, and you'd like to advertise the Tenant prefix being used, the subnet must be created under the BD and set to "public".
The common tenant has no different limitations to scale than any other tenant. The scalability guide should provide the relevant info for your release.
Robert
05-25-2015 07:55 AM
Thanks Pita and Robert.
Can you share to me, how many maximum subnets per BD ?
Thanks for your support.
05-27-2015 12:22 PM
In standalone, there is no limit to the amount of IP's you can place under an SVI. Each additonal subnet is added as a secondary IP under the SVI:
I would think this is the same for ACI :)
Joey
02-24-2016 04:22 PM
Hi Robert,
In regarding in the 'public' 'private' subnet mark, I think either Cisco document is wrong or there is a software bug on ACI 1.2.1k.
My subnet is advertised over external layer3 out eBGP session no matter where I configure it (BD or eBGP), and no matter what type (private to vrf or public).
"1900-ACI#show ip route bgp
10.0.0.0/24 is subnetted, 1 subnets
B 10.112.1.0 [20/0] via 172.16.1.10, 00:01:34
02-25-2016 06:24 AM
Hello
That is interesting. Could you please provide the following output from your border leaf? (the one that connects to the external router)
show ip prefix-list
as well as this moquery command from your APIC. where the subnet "17.17.2.1" can be replaced with your 10.112.1.0
admin@rtp1-apic1:~> moquery -c fvSubnet -f 'fv.Subnet.ip=="17.17.2.1/24"'
Total Objects shown: 1
# fv.Subnet
ip : 17.17.2.1/24
childAction :
ctrl :
descr : Tenant Blue in deadbeef Pod
dn : uni/tn-deadbeef-blue/BD-blue-bd2/subnet-[17.17.2.1/24]
lcOwn : local
modTs : 2015-12-24T11:57:27.799-05:00
monPolDn : uni/tn-common/monepg-default
name :
preferred : yes
rn : subnet-[17.17.2.1/24]
scope : public,shared
status :
uid : 15374
virtual : no
admin@rtp1-apic1:~>
02-25-2016 03:58 PM
Hi Robert,
The MO attributes:
admin@apic1:~> moquery -c fvSubnet -f 'fv.Subnet.ip=="10.112.1.1/24"'
# fv.Subnet
ip : 10.112.1.1/24
childAction :
ctrl :
descr :
dn : uni/tn-ITS/BD-MyAurionReals/subnet-[10.112.1.1/24]
lcOwn : local
modTs : 2016-02-25T13:33:58.524+10:00
name :
preferred : no
rn : subnet-[10.112.1.1/24]
scope : private
status :
uid : 15374
virtual : no
The prefix list seems empty for 10.x.x.x range:
rackf8_2# show ip prefix-list
ip prefix-list IPv4-deny-all: 1 entries
seq 1 deny 0.0.0.0/0
ip prefix-list IPv4-2621440-5474-18-2490368-shared-svc-leak: 1 entries
seq 2 permit 172.20.1.0/24
ip prefix-list IPv4-peer21-2457600-2490368-5474-shared-svc-intDST: 2 entries
seq 3 permit 192.168.2.1/24
seq 4 permit 192.168.1.1/24
ip prefix-list IPv4-peer21-2457600-2490368-49155-shared-svc-intDST: 2 entries
ip prefix-list IPv4-peer21-2457600-2621440-19-shared-svc-intDST: 2 entries
seq 3 permit 172.30.1.1/24
seq 4 permit 172.30.2.1/24
ip prefix-list IPv4-peer21-2457600-2621440-5475-shared-svc-intDST: 2 entries
ip prefix-list IPv4-peer21-2457600-exc-int-inferred-exportDST: 2 entries
seq 2 permit 130.112.3.1/24
seq 4 permit 130.112.1.1/24
ip prefix-list IPv4-peer21-2457600-2490368-10932-shared-svc-intDST: 2 entries
ip prefix-list IPv4-2621440-any-18-2555904-shared-svc-leak: 1 entries
seq 1 permit 172.20.1.0/24
For this:
This prefix-list is not modified by APIC at all regardless what type of subnet I configure them.
