Fault Acknowledgment per ACI Ports
Chris77
Hi All,
is there any chance to acknowledge faults port-wise? My intention is to acknowledge some port down Faults. As some sleeping servers are connected to those ports, removal of port config is not possible but I want to get rid of the corresponding faults.
Thanks.
BR
Only the specific fault which is ack will be hidden. And since the fault refers to a specific interface in a specific EPG, only that one will be hidden. If you have the same interface in multiple EPGs, then you'll need to ack all faults.
Cheers,
Sergiu
Sergiu.Daniluk
Hi @Chris77
You can to ack only the specific faults you want, by going to the System -> Faults -> select the fault you want to ack, right click on it and select Acknowledge fault:
Then you can go back to the Faults repository, click on the hammer logo and select Hide Ack Faults:
You have this option in Dashboard as well:
Cheers,
Sergiu
Thanks @Sergiu.Daniluk.
But does this means that the fault is acknowledged in general for the whole landscape or only for this specific port?
Cheers,
Sergiu
@Sergiu.Daniluk
Thank you Sergiu.
