How to bring interface UP connecting to APIC controllers?
CSCO11584685
So i made a mistake where i was shutting unused interfaces on leaf switches and shutdown the 4 ports going to two APIC controllers.
Now i have a single APIC connected to Fabric, and it is refusing to send commands to bring the Interfaces up with below error.
Error: the messaging layer was unable to deliver the stimulus (no replica is available)
I have oob access to the leaf switches, but i cant find a way to enable/noshut the interfaces. solution?
Fixed, supposed to put the FULL command. thanks to Cisco TAC.
leaf304(config)# int eth1/48
leaf304(config-if)# no shut
% Invalid command at '^' marker.
leaf304(config-if)# no shutdown
Dennis Mink
if you have access to the switches, cant you just go to the relevant physical ports on the switch configuration and do a "no shut" on the 4 interfaces?
Please remember to rate useful posts, by clicking on the stars below.
the command is not accepted on the leafs. i tried that.
leaf304(config)# interface e1/48
leaf304(config-if)#
imteerachotj
I think This case, move one or two APIC to connect available port (not disable) on leaf switch and waiting for synchronize.
After that you will enable physical interface on APIC.
Nik Noltenius
how are you even able to get into interface configuration mode on an ACI leaf switch???
Anyways: I've run into similar situations at least twice and finally found a very useful command:
setinservice
It basically brings back up all ports configured for fabric discovery or infrastructure purposes when they have accidentally been black-listed
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/nxos/cli/b_inxos_command_ref/b_inxos_command_ref_chapter_01010.html#wp2279509975
Nik
