How to change it into Cisco mode in leaf?
Leftz
Level 4
Level 4
Logon to leaf from apic. below is what I can see. its linux mode. How to change it into Cisco mode? Thanks
RedNectar
Hi @Leftz ,
Are you working with
  1. real hardware? or
  2. virtual hardware? or
  3. the ACI Simulator?
If working with the Simulator, you can't get access to the leaf switches
If working with real hardware, the prompt should be more like:
apic1# ssh leaf1201
Housley Fabric#1 ACI Lab
Password:
Last login: Fri Dec 15 07:12:44 2023 from 172.30.90.10
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2022, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Leaf1201#
Not sure what the deal is if working with virtual hardware, but I'd suspect that the hardware debug commands like vsh and vsh_lc(which is the debug shell for the line card) would not work on a virtual switch
RedNectar aka Chris Welsh.
RedNectar
Hi @Leftz ,
apic1# ssh leaf1201
Password:
Leaf1201#
Leftz
Level 4
Level 4
Thanks!
