How to check PSU status of LEAF from GUI and CLI
Hi Experts ,
How do I check the PSU status of LEAF switch from GUI and also from CLI .
RedNectar
Hi @Network_Sarovani ,
Firstly, IF there is a problem with a power supply it will show up as a Fault. There are many places you can look for Faults, but lets say Leaf2201 has a problem with a power supply:
Navigate to Fabric > Networking >> Pod1 > Leaf2201 (Node -2201) |> [Faults] tab.  There you should see something like:
Navigating to Fabric > Networking >> Pod1 > Leaf2201 (Node -2201) |> [Health] tab should also lead you to the same problem, so if you want warm fuzzy feelings and a positive indication that the PS is OK, you should probably look at the Health tab, or to to get hot flushes, navigate to Fabric > Networking >> Pod1 > Leaf2201 (Node -2201) > Chassis > Power Supply Units >1 [or 2] |> [Health] or [Faults] tab - where you'll see the same information, but with the addition of a [Stats] tab - you may have to play with the view range a bit to find what you are looking for (Oh. I made a pun! Watt you are looking for....)
From the CLI, there is a command that doesn't seem to work. At least this is what I saw - absolutely zilch!
apic1# show health leaf Leaf2201 inventory powersupply 1
apic1# show health leaf Leaf2201 inventory powersupply 2
so you may have to resort to moquery - this example shows the health for PS1 in leaf 2201
apic1# moquery -d topology/pod-1/node-2201/sys/ch/psuslot-1/health
Total Objects shown: 1
# health.Inst
childAction  :
chng         : 2
cur          : 100
dn           : topology/pod-1/node-2201/sys/ch/psuslot-1/health
maxSev       : cleared
modTs        : never
prev         : 98
rn           : health
status       :
twScore      : 100
updTs        : 2022-10-04T17:09:00.005+11:00
RedNectar aka Chris Welsh.
RedNectar
# health.Inst
childAction  :
chng         : 2
cur          : 100
maxSev       : cleared
modTs        : never
prev         : 98
rn           : health
status       :
twScore      : 100
Thank you @RedNectar
