01-15-2025 08:00 AM
Hello we know how to renumber an existing node id by removing the node from controller and re-register it with the new number but we are struggling with associated objects, specially static ports. Usually I save the objects I need to change in json, modify the json, delete the old objects and Post the new json in GUI. First challenge: saving multiple static ports from the GUI doesn't seem possible so I used moquery -c fvRsPathAtt -o json -f 'fv.RsPathAtt.dn*"1595"' but that creates a json file with attributes that are not accepted by Post in GUI, even if I delete all those unwanted lines using Notepad++ Find & Replace when I post a json payload with multiple static ports it always only creates the first one in the list omitting the other ones. Post in GUI or Postman have the same results.
{ "totalCount": "2", "imdata": [ { "fvRsPathAtt": {
"fvRsPathAtt": {
once this is figured out we will also need to change the port selectors associated with the old node id.
01-15-2025 08:16 AM - edited 01-31-2025 08:54 AM
We found a mitigation by adding parent EPG information manually and children structure but that means we would have to do this for every EPG found... very tedious.
"imdata": [
"fvAEPg": {
"attributes": {
"dn": "uni/tn-Tenant1/ap-AppProfile1/epg-EPG1",
"name": "EPG1"
"children": [
"fvRsPathAtt": {
"attributes": {
"tDn": "topology/pod-1/paths-101/pathep-[eth1/1]",
"encap": "vlan-100"
"fvRsPathAtt": {
"attributes": {
"tDn": "topology/pod-1/paths-102/pathep-[eth1/2]",
"encap": "vlan-101"
01-16-2025 12:46 PM - edited 01-31-2025 08:44 AM
Here's better approach to gather the static ports per EPG as json to allow editing the json and post in GUI but it doesn't allow to post to multiple EPGs, I need to find a way to include parent information.
APIC#bash
username@apic1:~>icurl -s -k https://localhost/api/node/class/fvAEPg.json?\rsp-subtree=children\&rsp-subtree-class=fvRsPathAtt\&rsp-subtree-include=required\&rsp-prop-include=config-only\&order-by=fvAEPg.dn\&rsp-subtree-filter='wcard(fvRsPathAtt.dn,"1595")'
change 1595 with the node id you are looking for.
@RedNectar can you assit with building the proper icurl to gather the info I need ? I need json format file that I can edit and change node ID and post it back to uni/ and configure multiple tenants/app/EPG static ports. tks
