How to renumber an existing node id and all of it's associated objets?
YanL
Hello we know how to renumber an existing node id by removing the node from controller and re-register it with the new number but we are struggling with associated objects, specially static ports. Usually I save the objects I need to change in json, modify the json, delete the old objects and Post the new json in GUI. First challenge: saving multiple static ports from the GUI doesn't seem possible so I used moquery -c fvRsPathAtt -o json -f 'fv.RsPathAtt.dn*"1595"' but that creates a json file with attributes that are not accepted by Post in GUI, even if I delete all those unwanted lines using Notepad++ Find & Replace when I post a json payload with multiple static ports it always only creates the first one in the list omitting the other ones. Post in GUI or Postman have the same results.
  "totalCount": "2",
  "imdata": [
      "fvRsPathAtt": {
"fvRsPathAtt": {
 once this is figured out we will also need to change the port selectors associated with the old node id.
YanL
We found a mitigation by adding parent EPG information manually and children structure but that means we would have to do this for every EPG found... very tedious.
"imdata": [
"fvAEPg": {
"attributes": {
"dn": "uni/tn-Tenant1/ap-AppProfile1/epg-EPG1",
"name": "EPG1"
"children": [
"fvRsPathAtt": {
"attributes": {
"tDn": "topology/pod-1/paths-101/pathep-[eth1/1]",
"encap": "vlan-100"
"fvRsPathAtt": {
"attributes": {
"tDn": "topology/pod-1/paths-102/pathep-[eth1/2]",
"encap": "vlan-101"
YanL
Here's better approach to gather the static ports per EPG as json to allow editing the json and post in GUI but it doesn't allow to post to multiple EPGs, I need to find a way to include parent information.
APIC#bash
username@apic1:~>icurl -s -k https://localhost/api/node/class/fvAEPg.json?\rsp-subtree=children\&rsp-subtree-class=fvRsPathAtt\&rsp-subtree-include=required\&rsp-prop-include=config-only\&order-by=fvAEPg.dn\&rsp-subtree-filter='wcard(fvRsPathAtt.dn,"1595")'
change 1595 with the node id you are looking for.
@RedNectar can you assit with building the proper icurl to gather the info I need ? I need json format file that I can edit and change node ID and post it back to uni/ and configure multiple tenants/app/EPG static ports. tks
