Issues in creating vPC.
Ramu Gajula
Hi Everyone,
I have N5K connected to leaf1 port 1/4 and leaf2 port 1/5 and i an trying to create a vPC.
while i am doing this, in the switch profile i selected two leafs and coming to interface selector, I am little confused here.
How do i select my member ports here?
if i select the range 1/4-5, i guess it will consider 1/4-5 on both the leafs. Please correct me if i am wrong.
Tomas de Leon
Ramu,
You simply create a Leaf1 Switch Profile with interface selector that has port 1/4.  Then repeat the task and create a Leaf2 Switch Profile with interface selector that has port 1/5.  These are then associated to the same VPC Interface Policy group.
Since they are different ports on different Switches, this is how it is done.
T.
Tomas de Leon
Ramu,
T.
Thank you, Tomas. It worked.
