12-31-2015 07:38 PM - edited 03-01-2019 04:54 AM
Hi Everyone,
I have N5K connected to leaf1 port 1/4 and leaf2 port 1/5 and i an trying to create a vPC.
while i am doing this, in the switch profile i selected two leafs and coming to interface selector, I am little confused here.
How do i select my member ports here?
if i select the range 1/4-5, i guess it will consider 1/4-5 on both the leafs. Please correct me if i am wrong.
Solved! Go to Solution.
01-01-2016 12:09 AM
Ramu,
You simply create a Leaf1 Switch Profile with interface selector that has port 1/4. Then repeat the task and create a Leaf2 Switch Profile with interface selector that has port 1/5. These are then associated to the same VPC Interface Policy group.
Since they are different ports on different Switches, this is how it is done.
T.
01-01-2016 12:09 AM
Ramu,
T.
01-01-2016 05:32 PM
Thank you, Tomas. It worked.
