LACP Lag Policy for VMM
dnoc43
Hello, We're getting the below major warning when setting up VMM integration.  We using vmware DVS 7.0.3.
Robert Burns
If you're running a verison prior to 5.2(2e), then you're likely hitting https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy56541.
Upgrade to 5.2(2e) or later to fix, or live with the non-impacting fault message.
Robert
Robert Burns
Robert
