MSO Site IP Addresses
alanjames9
Hey Guys,
I'm looking at staging two ACI sites with multi-site orchestrator (MSO) at a single location.  I only have access to one management network, so I will re-ip address the management interfaces of the 2nd DC ACI APICS to be in the new management network after i move them.  But, its it possible to change the IP Address of the sites within MSO? would this cause any issues with the MSITE or Tenant configuration?
- Thanks
Sergiu.Daniluk
Yes, the IP addresses of APICs can be changed for a Site. You can do it from: Sites > SiteName > APIC Controller URL
I never tested the change, but I think there shouls be no impact on existing  config.
Stay safe,
Sergiu
Robert Burns
No issues changing the APICs IP.  After you do, just refresh the Site data and should be no other impact assuming nothing in the Schemas have been changed.
Robert
Thanks!
Is it possible to change the management IP Address of two of three MSOs as well?
I was wanting to deploy all three MSO images to a single VMHost (non-case)  then move two VMs to a new host in a different data centre.
