To Test TOR Switch
ranjit123
Level 3
Level 3
Hello All,
We need to test the TOR switch in a ACI build process...
Its a new build and we need to test the switch reliability / failure and recovery
We need to do a graceful restart of the TOR switch without losing out or disassociating the switch or breaking the build
Is their any way we can do this and achieve this testing..
Ranjit
balaji.bandi
what model of TOR switches here ?
BB
Nexus 93180YC-FX
Yunus Emre DEV
hi,
You can connect TOR switch in isolation to Spine as a separate uplink?
what exactly do you want to do
Since you have already linked it as a separate Spine link, you can make any changes you want on the leaf side.
Sergiu.Daniluk
If I understand correctly, you want to do a restart of a leaf, right?
Easiest way is to do the reload command from CLI:
Leaf1201# reload
This command will reload the chassis, Proceed (y/n)? [n]: y
Cheers,
Sergiu
