10-04-2016 02:56 PM - edited 03-01-2019 05:03 AM
Hello experts,
Could you please confirm if the FEX HIF ports can be used on L3out ? I couldn't see any HIF port on the L3out interface profile static path it only shows the native leaf ports while they're visible in a regular App EPG as a static path.
Solved! Go to Solution.
10-04-2016 03:26 PM
Thanks for posting in the support forums.
FEX HIF ports are not supported for External Routed Networks and External Bridge Networks in ACI. FEX HIFs can only be configured for EPGs.
10-04-2016 03:26 PM
10-04-2016 03:33 PM
Thanks for your quick reply
