ACE 4700 , track gateway , icmp probe
majaj
i configure the the active ace to track gateway using icmp probe
when it can't ping the gateway it decrease the priority from 120 to 70,so the standby ACE take over
but when the ping back to the first ACE it doen't increase the priority from 70 to 120 again
what to do to solve this problem?
celiocarreto
Please paste your config.
I configured the same and it works.
My config:
primary ACE
under context Admin:
ft group 1
peer 1
peer priority 90
associate-context TEST
inservice
under context TEST:
ft track host GATEWAY
track-host 195.1.1.1
peer track-host 195.1.1.1
probe GATEWAY-ICMP
peer probe GATEWAY-ICMP
priority 50
peer priority 50
backup ACE
context Admin:
ft group 1
peer 1
priority 90
inservice
context TEST will be synchronized. Admin not!!
Hope it will help.
