ACE Active and Standby
philip-devos
I'm seeing a potential problem with the current ACE design, which is configured as one-arm.
What I’ve discovered is that the standby ACE show hit counts with the service policy as well as connections. According to what I understand, to maintain state between the ACE’s, both share connection and therefore not a concern.
What I see as a potential problem is:
  • The network sniff also revealed TCP retransmission between the RSERVER and the standby ACE
  • All probes fails on standby
According to my understanding is that the RSERVER should not try to make a connection to the standby.
I will appreciate if someone can shed some light on this.
Philip
Cesar Roque
Level 4
Level 4
Hi Philip
What si the status of the rserver in the standby ACE?  It is OPERATIONAL or OUTOFSERVICE?
Cesar R
ANS Team
--------------------- Cesar R ANS Team
The rservers on the standby ACE are all in operational state.
state                : OPERATIONAL (by default, unverified)
Interesting observation that I want to add.
The standby ACE, when it is in FSM_FT_STATE_STANDBY_HOT mode, show that the probes are failing, service-policy state is out of service and no curr or hit counts.
But, when in FSM_FT_STATE_STANDBY_COLD, the probes is working fine, state IN-SRVC, no current connections
