ACE bridge mode , FWSM routed mode
majaj
i have the following senario:
MSFC ---vlan 777----FWSM----vlan160---ACE----VLAN180
FWSM is working in routed mode and vlan 777 is shared between the MSFC and FWSM
ACE is working in bridged mode and vlan 160 is shared between the FWSM and ACE
vlan 180 is the server side vlan
i want he FWSM ip address to be the Server gateway while ACE module in
bridge mode
i create bvi interface but i can't ping from ACE to FWSM or from FWSM to
ACE
if i change ACE to routed mode , i can ping to FWSM
any body can help me in this issue?
Try adding following ACL entry to the ACE
access-list anyone line 20 extended permit icmp any any
Syed
Gilles Dufour
The config looks good.
I would look at the arp table on FWSM and ACE when the ping fails and also capture a sniffer trace of ACE tengig interface and see if the ping request goes out - on which vlan - and if we get a response.
Is evertyhing else working ?
Like ping through the ACE module ?
Your config does not show a 'no shutdown' on the vlan interface, but I assume you fixed that already.
Gilles.
