ACE checkpoint question
cricketbuff
I have a ACE checkpoint question. when u create a checkpoint to save the config on the ACE module where does the file get stored
dstolt
At an internal hidden data store that is not accessible by end users. If you want to save it as a file, you can use the the command "show checkpoint detail checkpointname > disk0: filename". That will allow you to see it or copy it off the system if you want.
Hope that helps,
Dan
HI,,
To display checkpoint information, use the show checkpoint command in Exec mode. The syntax of this command is:
show checkpoint {all | detail name}
The options and arguments are:
•all-Displays a list of all existing checkpoints
•detail name-Displays the running configuration of the specified checkpoint
For example, to display the running configuration for a specific checkpoint, enter:
host1/Admin# show checkpoint detail MYCHECKPOINT
Sachin
