ACE - Client Reset Connections to VIP
charles_barnett
When the client initiates a http connection to the VIP address, the connection fails because the client sends a RST back to the real server.
My real servers have the default gateway of the 6513 vlan interface.
Attached I have provided the Admin and test contexts, packet capture, and 6513 partical config.
Can someone please assist me on resolving this issue?
Roble Mumin
Level 3
Level 3
You only need the VLAN 32 configured on the MSFC because the "real server" VLAN 39 is routed through the ACE.
MSFC <---VLAN 32---> ACE <--- VLAN 39 ---> Real Servers. So the default gateway should be the ip of the ACE context.
EDIT: Also noticed you have no access-list on you're ACE interfaces. No access-list means no traffic.
Roble
