Ace connection establishment
pos_research
I have been reading the Ace configuration manual and other resources but cannot find clear answers. I would like to clarify the Ace behaviour for the following please (or recommended reading):
Q. How does the Ace handle connection establishment to a server with the sticky setting and pattern matching.
We have a custom protocol, and clients cannot be uniquely identified by their source ip/port.
As a result, we will be matching the layer4-payload with a regular expression for a unique user id in our custom protocol, and making this assignment sticky. The client also needs to log on to our server.
At which point does the Ace setup a full tcp/ip connection?
- after the pattern match?
- after the user logon?
- other?
That is, are we forced to pattern match every single packet? If not, how does the Ace recognise the client without matching the payload?
Thank-you!
For a LAyer7 VIP ( includes url/Generic TCP payload parsing).Following are the steps
1. ACE matches the VIP
2. Replies to client with SYN_ACK
3. Starts buffering the Data
4. It parses the data & select Server on the basis of Payload matching
5. Sends SYN to the selected server ( behave like a client to server)
6. Sends all the data it collected in step 3 to server
7. Splices the flow between client & server (By adjusting SYN & ACK numbers from the above mentioned two flows).
Syed Iftekhar Ahmed
