ACE Default Gateway/Routing
jason.williams
I've added a static default route to our ACE, "ip route 0.0.0.0 0.0.0.0 x.x.x.x"
It shows up in the configuration, but does not show up when I check the routing table with "show ip route".
Am I missing something?
Thanks.
jackwikinski
This normally happens when the ACE cannot reach the next hop in your route statement.
Thanks.
Jack.
jackwikinski
Thanks.
Jack.
It was user error.  I missed sending the vlan to the firewall.
But you are right, it couldn't reach the destination...
Thanks.
