ACE device authentication via ACS
scott-goodwin
Hi Guys,
I have setup my ACE module to authenticate against my ACS V4.1 AAA server.
However I keep receiving the message invalid password in the ACS logs when i try and login to the ACE module.
However the I know the username - pass is good as I already use the ACS and same user account to login to all the other IOS based switches and routers.
Hence do i need to add any custom values into the group settings on ACS to map the users to a role within ACE etc..
Scott
scott-goodwin
Thanks for the reply, I have now entered the custom variable
shell:Admin*Admin
however i still get ACS password invalid, yet the same user works for other devices, does the ace have a specific password policy as for test purposes I am using the password cisco
Cheers
Scott
The only thing i could imagine is the fact that there is a certain password minimal length coded within the ACE maybe that is your problem. IIRC the minimal length is 8 characters. So if your username password is shorter than that this could be the issue. Try adding a localuser and see for yourself.
username test password 0 test
Error: Password specified is not strong enough:it is too short
username test password 0 test1234 <- works
Other than that i honestly have no idea. :)
