ACE: enable http to configure ACE through web interface
gavin han
how do I enable it on ACE so that I can configure load balancing using web interface?
thanks in advance.
mmalwatt
Hi Gavin,
I think you are referring to the Device Manager which is only available for ACE Appliance. Once you have performed initial set up of the ACE through the CLI you can access the Device Manager by pointing your web browser to the management IP of the ACE, example https://192.168.1.1
Instructions on how to access the Device Manager and its functionality can be found here -
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/device_manager/guide/UGover.html#wp1109773
