ACE failover and preempt
niklaslund
We are trying to setup a ACE 4710 FT solution with following charateristics.
Standby ACE should takeover in case of primary ACE failure due to any of: completly lost (power failure), single interface down, reboot, lower tracking priority.
The standby ACE now becomes active and should stay active even if the "old" active (primary) comes back to nomal state.
Is this possible?
We want to limit the failure scenario to one failover.
Niklas
Hi Niklas,
Sorry I overlooked the part where you mentioned tracking was required.
Yup this possible, I tried this once when worked for TAC and I can assure, it works like a charm but
with a slight change, the ft tracking needs to be type host instead of interface.
Here is the paper tha explains how to accomplish this, please look for: Preemption with Fault-Tolerant Tracking
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5719/ps7027/ps8361/guide_c07-572616_ps7027_Products_White_Paper.html
__ __
Pablo
6 Replies 6
Pablo
Hi Niklas,
Yes you can achieve this on the ACE if you disable preemption from FT groups so that when a  failover occurs, the higher priority ACE will not force the Standby ACE to failover back to it. Without  'preempt', the priorities only apply if both ACE4710 were rebooted at  the same time and had to negotiate who becomes Active first.
Example;
ft group #
  peer 7
  no preempt
  priority 175
  peer priority 125
  associate-context [name]
  inservice
HTH.
__ __
Pablo
Pablo,
Understood, but at the same time you limit the failover detection to only be reachabillity on the crossover between the ACE boxes.
From Chapter 6 in the ACE Configuration manual (Configuring Redundant ACE Appliances):
You must configure preemption for tracking switchover to work. For details on
preemption, see the “Configuring Preemption” section.
So my initial characteristics are not met, we will not as an example be able to fail the primary ACE when an interface is down (tracking needed).
I would like to be able specify preempt per physical box, i.e. standby should be able to preempt the primary but not the other way around, this is how it works in IOS.
Actually ACE CLI lists preempt status per box “my” and “peer” but I cannot configure it that way and  meet my initial characteristics.
Niklas
Hi Niklas,
__ __
Pablo
Pablo,
Thanks, that's a good document; it got us on the right track.
Now the ACE behaves the way we want.
Actually some extra access-lists is needed, we put them in the switches....
This is needed to block ICMP echo from ACE, since the probe will continue to ping the failing gateway using the source IP of the interface where it has its default gateway configured when a connected vlan interface is down.
Niklas
Glad to help buddy
Have a great one!
__ __
Pablo
Niklaslund,
Please send me the link to chapter 6 that speaks about preemption.
Thank you,
John...
