ACE: ftp load balancing
gavin han
Hi, how to do ftp load balancing on ACE. does ACE auto senses ftp?
chrhiggi
Level 3
Level 3
Hello Gavin-
ACE can loadbalance FTP, the configuration for it requires you enable ftp inspection and a few other things depending if you are doing active or passive FTP.
Here are a few example documents:
http://docwiki.cisco.com/wiki/FTP_Load_Balancing_on_ACE_in_Routed_Mode_Configuration_Example
http://docwiki.cisco.com/wiki/FTP_Load_Balancing_on_ACE_in_Bridged_Mode_Configuration_Example
http://docwiki.cisco.com/wiki/FTP_Load_Balancing_on_ACE_in_One-Arm_Mode_Configuration_Example
Chris Higgins
