ACE in one-arm model. VIP on Client Side, servers in other vlan
gianni2006
Hello All
i have a LAN whit many servers,but only 2 need to be balanced. So i think in one-arm model, due to the higth trafic that not be pass trought ACE.
i have a vlan 900 where is the client side and the VIP also. (10.0.9.64/26)
the servers are in vlan 503 (10.12.3.0/24)
it mi first design with ONE-arm but i thinks something is missing, because doesn't work.
the configuration is the next:
MSFC:
svclc module 1 vlan-group 1,2,
svclc vlan-group 1 503,900-902
svclc vlan-group 2 511
interface Vlan503
description OSS_&_Otros
ip address 10.12.3.253 255.255.255.0
standby 10 ip 10.12.3.254
standby 10 priority 150
standby 10 preempt delay minimum 305
interface Vlan900
description MSF_<->_ACE
ip address 10.0.9.126 255.255.255.192
end
access-list 101 permit ip 10.12.3.0 0.0.0.255 10.0.9.64 0.0.0.63
access-list 101 deny ip any any
route-map From_Server_OSS_to_ACE permit 10
match ip address 101
set ip next-hop 10.0.9.125
ACE_1/admin#
ip route 0.0.0.0 0.0.0.0 10.0.9.126
context OSS
allocate-interface vlan 511
allocate-interface vlan 900
allocate-interface vlan 902
member Max20
ACE_1/OSS# sh run
Generating configuration....
access-list EVERYONE line 10 extended permit ip any any
access-list EVERYONE line 20 extended permit icmp any any
rserver host OSS_FES_1
description OSS_Front_End_Server_1
ip address 10.12.3.140
inservice
rserver host OSS_FES_2
description OSS_Front_End_Server_2
ip address 10.12.3.150
inservice
serverfarm host SERVER_farm_OSS
rserver OSS_FES_1
inservice
rserver OSS_FES_2
inservice
class-map match-all VIP-OSS
2 match virtual-address 10.0.9.66 any
policy-map type loadbalance first-match OSS-LB-POLICY
class class-default
serverfarm SERVER_farm_OSS
policy-map multi-match OSS-POLICY-MAP
class VIP-OSS
loadbalance vip inservice
loadbalance policy OSS-LB-POLICY
loadbalance vip icmp-reply
interface vlan 900
description Clients-side
ip address 10.0.9.125 255.255.255.192
access-group input EVERYONE
access-group output EVERYONE
service-policy input OSS-POLICY-MAP
no shutdown
maybe a i need to allocate the vlan 503 in OSS Context, any advice?
Thanks in advace,
Gianni From Chile
gianni2006
sorry it's my first post here and when i read all the post that i wrote, i figured out that the next command was missing on Vlan503:
ip policy route-map From_Server_OSS_to_ACE
i didn't know how to erase my post.
i hope the problem is going to be solved adding this comand.
anyway any advice of configuration or model to be used is welcome.
thanks gianni
Since you server are not behind the ACE in either bridge or routed mode add the follwoing to your config and use nat to get the traffic back to the ace.
This is how one-armed mode works.
ACE_1/OSS# sh run
inservice
inservice
rserver OSS_FES_1
inservice
rserver OSS_FES_2
inservice
class class-default
class VIP-OSS
nat dynamic 10 vlan 900
interface vlan 900
nat-pool 10 0.9.126 10 0.9.126 netmask 255.255.255.192 pat
no shutdown
route-map missing on vlan 900 SVI on MSFC.
Also ACL 101 doesnt feel right.
This ACL will forward all server response traffic to ACE. Which is against the reason of using One-arm mode. You should have a specific ACL entry which only take the traffic from Servers liastening on specific ports to ACE and all the remaining traffic should be allowed to bypass ACE.
For example if the servers 10.12.3.150 & 140 are listening on port 80 then the ACL should only say
access-list 100 permit tcp host 10.12.3.150 eq www any
access-list 100 permit tcp host 10.12.3.140 eq www any
Syed Iftekhar Ahmed
