ACE issue with traceroute
Ahmed Shahzad
ACE is load balancing on layer three devices. When trying to traceroute behind ACE does not showing any hop except ACE.
traceroute 58.27.191.17 source 192.168.25.6
Tracing the route to 58.27.191.17
1 192.168.25.137 0 msec 0 msec 0 msec
2 * * *
3 * * *
4 *
Shahzad.
Gilles Dufour
Configure icmp inspect error on all ace interfaces.
access-list 102 line 10 extended permit icmp any any
class-map match-all icmp_traffic
2 match access-list 102
policy-map multi-match icmp_inspect
class icmp_traffic
inspect icmp error
service-policy input icmp_inspect
Also be aware of
CSCsj64833-The network utility traceroute does not work for a configured ACE IP interface if the underlying protocol is UDP or TCP. Workaround: ICMP traceroute will work. The default of most traceroute utilities is UDP so a command line option might be necessary. For Linux, use the -I option.
Gilles Dufour
class icmp_traffic
inspect icmp error
Also be aware of
