ACE module and port redirection issue
jteixido
Team,
I attached my configuration for the servers that I configured. I configured the traffic to redirect to port 50081. I am able to get to the primary webpage, but when I click on any link on the webpage I get a 404 error.
Does anyone have any suggestions?
Thank you,
John...
5 Replies 5
Can you get the pages on port 50081 directly i.e using http://:50081
Syed
Syed,
The redirecting in working, when I type the url smtest I get the web page, but when I type the url smtest/sc; I get back a page not found error.
John...
Port Redirection will definitely work.
Question is if both real servers are really listening on the ports you configured & have the resources (web pages)you are trying to access.
This can be verified by hitting each real server using the url that gives you 404 ( including port# you defined under real server in th ehttp request).
For example If you are hitting a page using VIP http://10.128.170.95/page_A and it gives you an error
then try hitting the real servers on the ports configured and see if you get any errors
for e.g access reals (from the segment they are available)
http:///page_A:50081
and see if you get any errors.
Syed Iftekhar Ahmed
The /sc is actually another server on the same subnet.
Issue solved:
After some sniffer traces and working with TAC, we found that the issue was not with the ACE modules but with the config of the servers:
Jeff in your Virtual Host config for sc add smtest.bbtnet.com:80, you will also either need to remove the *:80 for the default_host of this plugin or make it more specific, like powerimage.bbtnet.com:80 or whatever that sites DNS name is, regen your plugin, copy to web servers and restart the JVM. Once that is done you should be able to retest.
John...
