ACE Module HTTP Insert / rewrite
celepar-damovo
Community Member
When ACE receives for example: www.cars.department.com.br , we need the url was changed to
www.cars.department.com.br/dept-cars/
The host remains the same.
How can I do this ? Action-list http header rewrite / insert ?
ajayku2
This was answered in one of the thread earlier.
you can achieve this by using HTTP redirection.
Use a class map to match the Host field / URI you want to match and foward the request to a redirect serverfarm with the right target.
http://www.cisco.com/en/US/partner/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/rsfarms.html#wp1046009
Rewriting the URI or the payload of pages is not supported. Only HTTP redirections will work with the ACE.
regards,
Ajay Kumar
Hi Kumar,
Thanks a lot
Sergio
