Bridge mode ACE matching anything other than VIP?
Craig_Baum_2
Hi, I have an ACE configured in bridged mode and we currently have various VIPs as class-map matches.
However I now need an effective wildcard match to match, say all tcp port eq www but the destination address could be any. So I effectively need to match any ip tcp port eq www.
Now applying that to a service policy inbound on the VLAN should match that. But without a VIP address how can the ACE terminate one TCP leg and then set up another to the serverfarm? Would it use the BVI address or can I add a set VIP type option?
So to confirm bridged ACE needing to match any IP going through with port 80 terminating and sending to serverfarm. Without a VIP how (if it does) work?
Thanks.
ajayku2
The below should work. We also say it "catch-all"
class-map match-any CM-HTTP-ANY
  2 match virtual-address 0.0.0.0 0.0.0.0 tcp eq http
regards,
Ajay Kumar
ajayku2
regards,
Ajay Kumar
Thanks.
Edit: we have tried it and it appears to work. Thank you.
