ACE - Need to permit access to allow remote management to servers
mcroberts
I am new to the ACE and having a problem figuring out how to allow the server team to manager their servers sitting behind the ACE modules. Load balancing is working great.
ex...
rserver1 = 172.17.252.10
rserver2 = 172.17.252.11
vip = 172.17.252.15
Currently, the server team is not able to use remote desktop, term services, etc... to manage the real servers...ie .10 and .11. My ACL permits everything and my multi-match policy map only permits access to the vip and applies load-balancing policies.
What do I need to configure to allow the server team to access their rserver IP addresses to manage each box?
If ACLs are in place then you need to make sure that traffic from server team can be routed successfully to/from the real servers.
Upstream routing devices should have routes for your real servers pointing to the ACE.
Syed iftekhar Ahmed
Syed iftekhar Ahmed
all of the routing is in place and the the real servers gateways are the ACE. I think my issue lies within the policy map permitting traffic in to the real IP addresses, but I cant find a combination that will permit the required traffic to the real servers IP addresses.
access-list IB extended permit ip any any
class-map match-any VIP
match virtual-address 172.17.252.15 tcp eq 80
match virtual-address 172.17.252.15 tcp eq 443
policy-map multi-match client-vip
class VIP
loadbalance vip inservice
loadbalance policy slb
loadbalance vip icmp-reply
interface vlan 252
ip address 172.17.252.4 255.255.255.192
service-policy input client-vip
access-group input IB
Policy maps are not needed for "Direct server Access". you just need an ACL and appropriate routes.
Syed
Hi, make sure that you configure the IB ACL on VLAN interface of the serverVLAN too, otherwise your return traffic is blocked.
Kr,
Dario
