ACE Policy is not working
wasiimcisco
I have ACE 4710 in context mode. I am doing internet browsing (Port 80) redirection to two proxy servers (Transparent Proxy) as well as I am using this ACE box for multiple other servers load balancing.
I have multiple policies applied on my LAN interface (VLAN 300) where all the users and servers are connected.
Now I am facing problem with one application (PLATTS) which is oil company related application. This application is working fine while directly connected with Internet (extrenal internet connection) or by giving explicit proxy in the user browser.
But In transparent proxy This application is not working and my company policy only allow the transparent proxy not explicit proxy.
Now if on my interface vlan 300 i will remove the service-policy input PM_MAIN_BCPROXY my application will start working but i cant redirect the port 80 traffic to my proxy servers which is also my requirement.
interface vlan 300
  description ACE-INSIDE CONTEXT RACK1
  ip address 192.168.0.65 255.255.255.224
  alias 192.168.0.73 255.255.255.224
  peer ip address 192.168.0.66 255.255.255.224
  no normalization
  mac-address autogenerate
  no icmp-guard
  access-group input acl-in
  nat-pool 5 172.23.16.5 172.23.16.5 netmask 255.255.255.255 pat
  nat-pool 4 172.23.16.4 172.23.16.4 netmask 255.255.255.255 pat
  nat-pool 3 172.23.16.3 172.23.16.3 netmask 255.255.255.255 pat
  nat-pool 1 172.23.16.2 172.23.16.2 netmask 255.255.255.255 pat
  service-policy input PM_BYPASS_PLATTS
  service-policy input PM_ENOC_Servers
  service-policy input PM_RT_FAX
  service-policy input PM_ITSM_Web_Server
  service-policy input PM_ITSM_MAPP_Server
  service-policy input PM_BYPASS_FOR_LAN_HTTP
  service-policy input PM_BYPASS_HTTP
This application use multiple destinations for connectivity and I have even tried by passing the destination IP addresses by making bypass policy but still no luck.
I want this application to work as well as redirection of port 80. I even try re-ordering the policy sequence but no luck. Can you please help me out how to achieve this application to work as well as redirectino of port 80 for Internet.
I have attached the full configuration as welll.
I will be very thankful if someone can help me on this.
Jorge Bejarano
Level 4
Level 4
Which are the VIP, serverfarm and rserver involved into the situation?
This application has no VIP and serverform.
My traffic is passing through the ACE and when traffic passing ACE policy for redirection of port 80 is droping traffic. If i remove my last service policy on the interface this application will start working
wasiimcisco
Waiting for someone to help me out
request you to please assist me
