ACE: probe with serverfarm not working
mlopacinski
Hello
When i use one probe configured for port 8080 with serverfarm which users realservers port 8080 everything works fine. But i wanted to create one generic probe and use for all of my serverfarms. I hoped that this generic (tcp probe) probe will use ports of each serverfarm, but it uses default port 80. Is it possible to use one generic probe for all serverfarms which have different ports ? How ?
It worked in CSM, but it does not work in ASA :(
Thanx
Gilles Dufour
if you do not define a port in the probe config, it should take the one defined in the serverfarm.
Just like the CSM.
Gilles.
