Cisco ACE module How to configure application acceleration
Sonugnair_2
Hi all,
Apart from application load balancing the ACE service module also does application accleration and some other features like bandwidth reduction like delta encoding,compression and dynamic browser caching? Is there any configuration examples for the above features. Also does the ACE service module support all the features provided by the ACE appliance?
Thanks and Regards
Sonu
Gilles Dufour
The features you describe are only available on the ace appliance currently.
The documentation for the appliance should have the commands that you need to set up those features.
Gilles.
