ACE- SSL Termination with ssl url rewrite (URGENT)
majaj
i just upgraded to ACE 2.0
ssl termination with url rewrite not working
when i put https://172.16.211.50 i am redirected to http://172.16.211.50:9080/cseipoms
i want the ACE to terminate the SSL and the user get the following: (SECURE)
https://172.16.211.50/cseipoms
i don't want the user to redirected to nonesecure page
know i get the SSL Certificate popup after that i am redirected to nonsecure page
7 Replies 7
Gilles Dufour
what is your config ?
And is your server using a redirect to send you to http or is it a hard link ?
the rewrite function only works with the redirect.
Gilles.
thanks
know its working fine , but still i have problem , when i put user name and password in the web page, it show session timeout
the application developer said that because the traffic is going to different server each time
Persistence-rebalance does not solve the problem , do i need to configure sticky group?
yes, you will need some form of stickyness.
Gilles.
Is there a sample config of how to config url re-write? I thought wasn't available until the 3.0 ace code comes out.
Jeff
The documenation is here :
http://www.meetic.be/meetic.php?url=/home/index.php
Gilles.
Gilles,
Can you check the url again this seems to be an online dating site.
Jeff
a12288
Level 3
Level 3
I have the exact problem, did you figure it out?
