ACE Sticky Connections, Show Conn Output and Show serverfarm
Plinio Brandao
Hi Community,
I'm deploying a Cisco ACE module and I have some questions about sticky connections and about the output of the show conn command and show serverfarm command.
I have the follwoing configuration:
rserver host srv_1
  ip address 10.4.11.14
  inservice
rserver host srv_2
  ip address 10.4.11.18
  inservice
serverfarm host farm_144
  rserver srv_1 144
    weight 1
    inservice
  rserver srv_2 144
    weight 3
    inservice
sticky ip-netmask 255.255.255.255 address source st_host144
  timeout 10080
  serverfarm farm_144
class-map match-all vip_144
  2 match virtual-address 10.4.11.208 tcp eq 143
policy-map type loadbalance first-match lb_144
  class class-default
policy-map multi-match policy_vip_webcache
  class vip_webcache_144
    loadbalance vip inservice
    loadbalance policy lb_144
    loadbalance vip icmp-reply active
    nat dynamic 411 vlan 411
We can assume that service policy was applied at the interface vlan. So, let's go to the questions:
1- If sticky is enabled the output command "show conn" should show just one entry by ip address?
The real output is:
DC01-ACE-01-PRIMARY-SW1/context_servidores# show conn | inc :143
333046     1  in  TCP   411  10.2.158.87:3616      10.4.11.208:143       ESTAB
286390     3  in  TCP   411  10.2.158.87:3562      10.4.11.208:143       ESTAB
310233     1  in  TCP   411  10.1.5.87:3424        10.4.11.208:143       ESTAB
Look that the ip address 10.2.158.87 is shown 2 times. In same times, the same ip address is shown 4 times to the same VIP and the same port. Is it a normal behavior?
2- According to the configuration, the srv_2 has weight 3 and srv_1 has weigth 1, but the output of show serverfarm show somethin strange:
DC01-ACE-01-PRIMARY-SW1/context_servidores# show serverfarm farm_144
serverfarm     : farm_144, type: HOST
total rservers : 2
state          : ACTIVE
DWS state      : DISABLED
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: srv_1
       10.4.11.14:144        1   OPERATIONAL     11         386        0
   rserver: srv_2
       10.4.11.18:144        3   OPERATIONAL     35         66         0
We can see that the weight is working good, but the total of connections is higher at srv_1 than srv_2. Why?
Somebody can help me to understand better this problem of if its a normal behavior?
Thanks in advance!!
gaursin2
Answer to your first q? will be that "show conn" for a L4 policy map will show every connection with different "SIP,SPORT,DIP and DPORT". So if any variable i amobg four change it will  be a new connection (despite of source sticky). in your case I can see the SPORT for two connection of 10.2.158.87 is different. So although because of SOURCE STICKY they will hit same rserver but conection will be two.
Regarding second q? i can see there is server1 is showing a lot more connection than server2 despite weight of server2 is triple to that of server1. but again you are using SOURCE STICKY, so there might be a possibillity that source IP's stick with server1 opens a lot more conection than comapre to IP's bind with server2. Weight will come in picture for every new connection from every new IP (which has not binded to sticky).
hope it resolves your query.....
Hi Gaurav,
About question 1, I got some informations too. It's perfectly normal the client open 2 or more connections at the same time. The client's application is the responsable. We removed the ACE and put the client directly to the server and the result of the total connections opened was the same.
About question 2, I made some "clears" on the serverfarm, the sticky database and after that, the numbers were more real.
DC01-ACE-02-SECONDARY-SW1/context_servidores# sh serverfarm farm_webcache_144
serverfarm     : farm_webcache_144, type: HOST
total rservers : 2
state          : ACTIVE
   rserver: srv_webcache_1
       10.4.11.14:144        1   OPERATIONAL     1025       15499      4436
   rserver: srv_webcache_2
       10.4.11.18:144        2   OPERATIONAL     1794       33471      471
Anyway thank you very much for your feedback.
Plínio Monteiro
