ACE - VIP ping issue
deephazz02
for some reason I cannot ping the VIP I configured on one ACE context.
Here is a sample of the config:
class-map match-any L4_kitrik
2 match virtual-address 10.0.0.1 any
class-map type http loadbalance match-any L7_kitrik_URL
2 match http url .*
class-map type management match-any REMOTE_ACCESS
2 match protocol ssh any
3 match protocol icmp any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
class REMOTE_ACCESS
permit
policy-map type loadbalance first-match L7_kitrik_LBPolicy
class L7_kitrik_URL
policy-map multi-match L4_kitrik_LBPolicy
class L4_kitrik
loadbalance vip inservice
loadbalance policy L7_kitrik_LBPolicy
loadbalance vip icmp-reply active
loadbalance vip advertise active
interface vlan 100
ip address 10.0.0.1 255.255.255.0
no normalization
no icmp-guard
access-group input ALL
access-group output ALL
service-policy input REMOTE_MGMT_ALLOW_POLICY
service-policy input L4_kitrik_LBPolicy
no shutdown
I am coming from VLAN 100.
I can ping 10.0.0.1 from different devices but not 172.16.255.1. I know connectivity is ok since I am able to telnet 172.16.255.1 into port 80... ping still does not work.
Any idea?
Regards.
Gilles Dufour
change your class-map into :
2 match virtual-address 10.0.0.1 tcp any
or
2 match virtual-address 10.0.0.1 tcp eq 80
Right now I believe your icmp traffic is interpreted as http due to your policy and therefore it fails.
Gilles.
I just tried it but no luck.
I check this configuration against some other contexts configured for http loadbalancing and the other configurations were just the same.
I need to check the servers now to see wether they reply icmp packets or not.
if you have the class-map I configured, the icmp traffic will not be forwarded to the servers.
The ace module will respond.
Share your complete config if you want me to have a look.
Also check if the ping gets to the ace module with a sniffer trace in front of the module.
You can 'monitor' the tengig interface of the module to capture a trace.
you can send me the config to gdufour@cisco.com if you want to keep it private.
Gilles.
ICMP replies comes from the servers configured for the vip address. Check the icmp connection status to the servers and if probes configured, check them too..
