05-22-2008 04:53 AM
The VIPs on my ACE configuration are not advertising themselves. They don't show up in the ARP table in the upstream router/firewall.
The VIPs are configured to be "Inservice". I have probes that are successful. I can access the real servers behind the ACE successfully via pings, ssh, http, etc.
Here's part of my config:
policy-map multi-match int204-n2
class SMTP_Inbound_LB
loadbalance vip inservice
loadbalance policy SMTP_Inbound_LB-l7slb
loadbalance vip icmp-reply active
Is there anything else I need to add? The VIPs aren't responding to pings. The VIPs aren't showing up in the arp table of the upstream router/firewall.
I know there used to be a "loadbalance vip advertise" command, but that command is no longer valid or available.
I am running code version A1.8(0) on the ACE 4710 appliance.
I have this ACE also configured as a bridge. Is there something special I need to add to make the VIPs advertise themselves, respond to pings, etc.?
Thank you.
05-22-2008 06:58 AM
"loadbalance vip advertise" is for Route health injection, which is not supported on ACE appliance.
Have you applied acls to the client vlan interfaces.
Syed
05-22-2008 07:03 AM
Hi Syed,
Thanks for your response.
There are no ACLs on the client VLAN interfaces.
There is a global ACL on the entire ACE, permitting all ICMP, TCP, UDP, and IP traffic.
I can access all real servers behind the ACE in bridged mode, so there is no restriction in traffic flow. I just can't ping the VIPs and the VIPs don't show up in the arp table of the upstream router/firewall/default-gateway.
Is there another way to advertise the VIPs or refresh them into "inservice"?
Thank you,
Herman
05-22-2008 07:40 AM
Is the policy assigned to an interface ?
Does it show inservice with the following command ?
show service policy int204-n2
Do you have other vip working ?
Is the vip part of your local subnet ?
Can you ping the local interface ?
Does the ace have an arp entry for the upstream ?
Gilles.
05-22-2008 07:48 AM
Hi Gilles,
Yes, the policy is assigned to both VLAN interfaces of the bridge-group.
Yes, all VIPs show INSERVICE when I run the command "show service-policy int204-n2"
None of the VIPs are responding to pings or showing up in arp table of the upstream router/firewall.
The VIPs are part of the local subnet. I can't ping the local interface (BVI interface) of the bridge-group from the upstream firewall/router.
Yes, the ACE has an arp entry for the upstream router/firewall. The upstream firewall is also the ACE's default-gateway for this context.
Herman
05-25-2008 09:27 AM
Hi Herman,
Here's a checklist I use if I'm running into problems:
1: ACL, make sure an inbound ACL is on the client-side interface.
2: Service policy containing the multimatch policy is applied only on the client side interface.
3: Make sure the probes see the servers as up
4: Telnet from the ACE to the servers to make sure there's connectivity
Hope that helps
06-16-2008 12:05 PM
When I encountered this issue, it got fixed with two separate ways. One is that the interface I applied the policies on were originally shutdown. Once I activated it, the ARP entries started showing. The other time this happened to me, I did activated the interface but it still didn't show. What fixed it was a reload of the ACE module to manually have the ACE re-arp. Clearing the arp by CLI wasn't working so I scheduled an off-hours reload.
12-09-2008 03:05 PM
All,
As of this writing (12/9/2008), can anyone confirm whether or not RHI is supported on the ACE appliance today??
Thanks!
-Lloyd
12-15-2008 01:49 AM
It's not supported on the current release of ACE Appliance software (A3(2.1) released 21-Nov-2008)
Andrew.
04-10-2009 02:31 AM
Looks like RHI is still not supported on ACE appliance..?? If you are trying to achive site to site redundancy without the use of GSSs.. what would be the preferred method??
