ACE WAF cipher suite selection logic
MATIJA PETROVIC
Hello everyone!
when ACE WAF is terminating SSL connections, what logic is used to select cipher suite? Could this be influenced by configuration?
My specific objective is to use CBC as last resort only due to CVE-2011-3389 vulnerability.
For example, client offers:
Cipher Suites (13 suites)
Cipher Suite: Unknown (0x00ff)
Cipher Suite: TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x0039)
Cipher Suite: TLS_DHE_DSS_WITH_AES_256_CBC_SHA (0x0038)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA (0x0035)
Cipher Suite: TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x0033)
Cipher Suite: TLS_DHE_DSS_WITH_AES_128_CBC_SHA (0x0032)
Cipher Suite: TLS_RSA_WITH_RC4_128_SHA (0x0005)
Cipher Suite: TLS_RSA_WITH_RC4_128_MD5 (0x0004)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
Cipher Suite: TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA (0x0016)
Cipher Suite: TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA (0x0013)
Cipher Suite: SSL_RSA_FIPS_WITH_3DES_EDE_CBC_SHA (0xfeff)
Cipher Suite: TLS_RSA_WITH_3DES_EDE_CBC_SHA (0x000a)
Server (WAF) selects
Thanks.
viktorzhi
Hello Matija,
Cisco user guide 6.1 has following explanation;
Specifically, the default Cipher Suite list it uses is:
ALL:!ADH:!EXPORT:!SSLv2:!LOW:+HIGH:+MEDIUM
You can limit the cipher suites that are accepted by the ACE Web Application Firewall on the port by
choosing custom from the SSL Cipher Suite menu. In the text field that appears, enter the set of cipher
suites to be permitted in standard OpenSSL Cipher string format, as described here:
http://www.openssl.org/docs/apps/ciphers.html
For example, to permit only algorithms that use keys that have a length of 128 bits or greater and not
anonymous DH, use:
HIGH:MEDIUM:!ADH
This is equivalent to specifying:
DHE-RSA-AES256-SHA:DHE-DSS-AES256-SHA:AES256-SHA
:EDH-RSA-DES-CBC3-SHA:EDH-DSS-DES-CBC3-SHA:
DES-CBC3-SHA:DES-CBC3-MD5:DHE-RSA-AES128-SHA:
DHE-DSS-AES128-SHA:AES128-SHA:DHE-DSS-RC4-SHA:
KRB5-RC4-MD5:KRB5-RC4-SHA:RC4-SHA:RC4-MD5:
RC2-CBC-MD5:RC4-MD5:KRB5-DES-CBC3-MD5: KRB5-DES-CBC3-SHA
If the client is not capable of using any of the SSL Cipher Suites specified, the connection is not
permitted. The event log will show a warning level event similar to: “Terminating HTTP session: 400
Bad request.”
BEWARE when deploying custom cipher suite, WAF MGR doesn't verifies it.
Kind regards,
Viktor
Hello Viktor,
thank you for your contribution. I was aware of the possibility to select cipher suites. My objective is to prioritize, to put in desired order cipher suites, making the CBC suites the last resort only.
Unfortunately Cipher Suite list allows only to include or exclude cipher suites. The order of selecting suites in a list is not documented (or I am unable to find it?).
Thanks again and kind regards,
Matija.
Dear Matija,
by looking at default Cisco cipher list 'ALL:!ADH:!EXPORT:!SSLv2:!LOW:+HIGH:+MEDIUM' one can conclude following;
- include ALL ciphers except eNULL ciphers,
- permanently delete anonymous DH cipher,
- permanently deletes EXPORT encryption algorithms (includes 40&56 bit algos),
- permanently delete SSLv2,
- permanently delete LOW,
- move HIGH to the end and have MEDIUM at the end of the list.
Since BEAST attack hits SSLv3 and TLSv1.0, cipher list should be reordered ''ALL:!ADH:!EXPORT:!SSLv2:!LOW:+MEDIUM:+HIGH:+SSLv3' moving MEDIUM in front of HIGH and putting SSLv3 cipher suite at the end of cipher list.
Comparing results of both cipher lists, one can find CBC's at lower position in modified cipher list.
openssl ciphers -v 'ALL:!ADH:!EXPORT:!SSLv2:!LOW:+HIGH:+MEDIUM'
ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AESGCM(256) Mac=AEAD
ECDHE-ECDSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AESGCM(256) Mac=AEAD
ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
ECDHE-ECDSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AES(256)  Mac=SHA384
ECDHE-RSA-AES256-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA1
ECDHE-ECDSA-AES256-SHA  SSLv3 Kx=ECDH     Au=ECDSA Enc=AES(256)  Mac=SHA1
SRP-DSS-AES-256-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=AES(256)  Mac=SHA1
SRP-RSA-AES-256-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=AES(256)  Mac=SHA1
DHE-DSS-AES256-GCM-SHA384 TLSv1.2 Kx=DH       Au=DSS  Enc=AESGCM(256) Mac=AEAD
DHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=DH       Au=RSA  Enc=AESGCM(256) Mac=AEAD
DHE-RSA-AES256-SHA256   TLSv1.2 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA256
DHE-DSS-AES256-SHA256   TLSv1.2 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA256
DHE-RSA-AES256-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA1
DHE-DSS-AES256-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA1
DHE-RSA-CAMELLIA256-SHA SSLv3 Kx=DH       Au=RSA  Enc=Camellia(256) Mac=SHA1
DHE-DSS-CAMELLIA256-SHA SSLv3 Kx=DH       Au=DSS  Enc=Camellia(256) Mac=SHA1
AECDH-AES256-SHA        SSLv3 Kx=ECDH     Au=None Enc=AES(256)  Mac=SHA1
SRP-AES-256-CBC-SHA     SSLv3 Kx=SRP      Au=None Enc=AES(256)  Mac=SHA1
ECDH-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(256) Mac=AEAD
ECDH-ECDSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(256) Mac=AEAD
ECDH-RSA-AES256-SHA384  TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(256)  Mac=SHA384
ECDH-ECDSA-AES256-SHA384 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(256)  Mac=SHA384
ECDH-RSA-AES256-SHA     SSLv3 Kx=ECDH/RSA Au=ECDH Enc=AES(256)  Mac=SHA1
ECDH-ECDSA-AES256-SHA   SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=AES(256)  Mac=SHA1
AES256-GCM-SHA384       TLSv1.2 Kx=RSA      Au=RSA  Enc=AESGCM(256) Mac=AEAD
AES256-SHA256           TLSv1.2 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA256
AES256-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA1
CAMELLIA256-SHA         SSLv3 Kx=RSA      Au=RSA  Enc=Camellia(256) Mac=SHA1
PSK-AES256-CBC-SHA      SSLv3 Kx=PSK      Au=PSK  Enc=AES(256)  Mac=SHA1
ECDHE-RSA-DES-CBC3-SHA  SSLv3 Kx=ECDH     Au=RSA  Enc=3DES(168) Mac=SHA1
ECDHE-ECDSA-DES-CBC3-SHA SSLv3 Kx=ECDH     Au=ECDSA Enc=3DES(168) Mac=SHA1
SRP-DSS-3DES-EDE-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=3DES(168) Mac=SHA1
SRP-RSA-3DES-EDE-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=3DES(168) Mac=SHA1
EDH-RSA-DES-CBC3-SHA    SSLv3 Kx=DH       Au=RSA  Enc=3DES(168) Mac=SHA1
EDH-DSS-DES-CBC3-SHA    SSLv3 Kx=DH       Au=DSS  Enc=3DES(168) Mac=SHA1
AECDH-DES-CBC3-SHA      SSLv3 Kx=ECDH     Au=None Enc=3DES(168) Mac=SHA1
SRP-3DES-EDE-CBC-SHA    SSLv3 Kx=SRP      Au=None Enc=3DES(168) Mac=SHA1
ECDH-RSA-DES-CBC3-SHA   SSLv3 Kx=ECDH/RSA Au=ECDH Enc=3DES(168) Mac=SHA1
ECDH-ECDSA-DES-CBC3-SHA SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=3DES(168) Mac=SHA1
DES-CBC3-SHA            SSLv3 Kx=RSA      Au=RSA  Enc=3DES(168) Mac=SHA1
PSK-3DES-EDE-CBC-SHA    SSLv3 Kx=PSK      Au=PSK  Enc=3DES(168) Mac=SHA1
ECDHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AESGCM(128) Mac=AEAD
ECDHE-ECDSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AESGCM(128) Mac=AEAD
ECDHE-RSA-AES128-SHA256 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA256
ECDHE-ECDSA-AES128-SHA256 TLSv1.2 Kx=ECDH     Au=ECDSA Enc=AES(128)  Mac=SHA256
ECDHE-RSA-AES128-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(128)  Mac=SHA1
ECDHE-ECDSA-AES128-SHA  SSLv3 Kx=ECDH     Au=ECDSA Enc=AES(128)  Mac=SHA1
SRP-DSS-AES-128-CBC-SHA SSLv3 Kx=SRP      Au=DSS  Enc=AES(128)  Mac=SHA1
SRP-RSA-AES-128-CBC-SHA SSLv3 Kx=SRP      Au=RSA  Enc=AES(128)  Mac=SHA1
DHE-DSS-AES128-GCM-SHA256 TLSv1.2 Kx=DH       Au=DSS  Enc=AESGCM(128) Mac=AEAD
DHE-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=DH       Au=RSA  Enc=AESGCM(128) Mac=AEAD
DHE-RSA-AES128-SHA256   TLSv1.2 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA256
DHE-DSS-AES128-SHA256   TLSv1.2 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA256
DHE-RSA-AES128-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA1
DHE-DSS-AES128-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA1
DHE-RSA-CAMELLIA128-SHA SSLv3 Kx=DH       Au=RSA  Enc=Camellia(128) Mac=SHA1
DHE-DSS-CAMELLIA128-SHA SSLv3 Kx=DH       Au=DSS  Enc=Camellia(128) Mac=SHA1
AECDH-AES128-SHA        SSLv3 Kx=ECDH     Au=None Enc=AES(128)  Mac=SHA1
SRP-AES-128-CBC-SHA     SSLv3 Kx=SRP      Au=None Enc=AES(128)  Mac=SHA1
ECDH-RSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(128) Mac=AEAD
ECDH-ECDSA-AES128-GCM-SHA256 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AESGCM(128) Mac=AEAD
ECDH-RSA-AES128-SHA256  TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(128)  Mac=SHA256
ECDH-ECDSA-AES128-SHA256 TLSv1.2 Kx=ECDH/ECDSA Au=ECDH Enc=AES(128)  Mac=SHA256
ECDH-RSA-AES128-SHA     SSLv3 Kx=ECDH/RSA Au=ECDH Enc=AES(128)  Mac=SHA1
ECDH-ECDSA-AES128-SHA   SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=AES(128)  Mac=SHA1
AES128-GCM-SHA256       TLSv1.2 Kx=RSA      Au=RSA  Enc=AESGCM(128) Mac=AEAD
AES128-SHA256           TLSv1.2 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA256
AES128-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA1
CAMELLIA128-SHA         SSLv3 Kx=RSA      Au=RSA  Enc=Camellia(128) Mac=SHA1
PSK-AES128-CBC-SHA      SSLv3 Kx=PSK      Au=PSK  Enc=AES(128)  Mac=SHA1
DHE-RSA-SEED-SHA        SSLv3 Kx=DH       Au=RSA  Enc=SEED(128) Mac=SHA1
DHE-DSS-SEED-SHA        SSLv3 Kx=DH       Au=DSS  Enc=SEED(128) Mac=SHA1
SEED-SHA                SSLv3 Kx=RSA      Au=RSA  Enc=SEED(128) Mac=SHA1
ECDHE-RSA-RC4-SHA       SSLv3 Kx=ECDH     Au=RSA  Enc=RC4(128)  Mac=SHA1
ECDHE-ECDSA-RC4-SHA     SSLv3 Kx=ECDH     Au=ECDSA Enc=RC4(128)  Mac=SHA1
AECDH-RC4-SHA           SSLv3 Kx=ECDH     Au=None Enc=RC4(128)  Mac=SHA1
ECDH-RSA-RC4-SHA        SSLv3 Kx=ECDH/RSA Au=ECDH Enc=RC4(128)  Mac=SHA1
ECDH-ECDSA-RC4-SHA      SSLv3 Kx=ECDH/ECDSA Au=ECDH Enc=RC4(128)  Mac=SHA1
RC4-SHA                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=SHA1
RC4-MD5                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=MD5
PSK-RC4-SHA             SSLv3 Kx=PSK      Au=PSK  Enc=RC4(128)  Mac=SHA1
openssl ciphers -v 'ALL:!ADH:!EXPORT:!SSLv2:!LOW:+MEDIUM:+HIGH:+SSLv3'
Kind regards,
Viktor
