ACE with FT: configure alias IP on bvi interfaces?
martabaro
We have two ACE modules configured for FT and bridge mode. Do we have to configure alias IP addresses on the bvi interfaces (I mean the bvi interfaces where client and server vlans are bridged)?.
interface bvi 125
  ip address 10.10.10.3
  no shutdown
interface vlan 125
  bridge-group 125
interface vlan 126
  bridge-group 125
OR:
interface bvi 125
  alias address 10.10.10.3
  no shutdown
interface vlan 125
  bridge-group 125
interface vlan 126
  bridge-group 125
Thanks and kind regards
ajay chauhan
Level 7
Level 7
This might help.
Configuring an Alias IP Address
When configuring a redundant configuration with active and standby modules, you can configure a VLAN interface that has an IP address that floats between active and standby modules. To configure a floating address for the BVI, use the alias command in its interface configuration mode. The syntax for the command is:
alias ip_address mask
The ip_address mask arguments are the address and subnet mask of the interface. Enter the IP address and subnet mask in dotted-decimal notation.
For example, to configure an IP address and mask for a BVI, enter:
host1/Admin(config-if)# alias 10.0.0.15 255.255.255.0
To delete the alias IP address from a BVI, enter:
host1/Admin(config-if)# no alias 10.0.0.15 255.255.255.0
kkataja
Typically you do not need alias addresses in bridged contexts. They are used as next hops in a routed context environment.
martabaro
Thanks to both!
My doubt was with the only Ip address i will have to configure, the one that belongs to the vlan interfaces themselves (the unique IP for client and server vlan interfaces).
