ACE with GSS Integration
ranjith.kanisan
Dear Team,
I am very new to GSS concept. Any way we are planning to integrate GSS with Cisco ACE. Kindly suggest is there any design procedure for GSS with ACE. Also share the basic configuration document and design document GSS with ACE integration.
Thanks in advance.
Ranjith
ajayku2
ajayku2
Hi Ranjith,
You may refer :
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v3.1/configuration/gui/gslb/guide/Intro.html#wp1051281
read section :
Globally Load Balancing with the GSS
regards,
Ajay Kumar
