ACE20 Module - is it possible to capture probe traffic?
Fernando Bello
Hello all,
I am having a weird problem. I have an HTTPS probe that sometime fail, sometimes does not fail.
probe tcp TCP_443
  port 443
  interval 20
  passdetect interval 20
probe https TEST-HTTPS
  interval 20
  request method head url https://10.31.1.210/default.htm
  expect status 200 200
The probe that sometimes fails is the TEST-HTTPS. The TCP_443 probe works perfectly well.
The ACE is configured in bridge mode.
Is it possible to capture the PROBE traffic on the ACE side?
thanks in advance,
Fernando
2 Accepted Solutions
Fernando,
It sounds good then.
Mark it if it was helpful.
Good luck!
Jorge
Cesar Roque
Level 4
Level 4
Hi Fernando,
Just one observation, the probe should look like this:
  interval 20
  request method head url /default.htm
Cesar R
ANS Team
--------------------- Cesar R ANS Team
7 Replies 7
Jorge Bejarano
Level 4
Level 4
Fernando,
This type of traffic is not captured by using the ACE's capture.
I would recommend to run a Wireshark capture on the servers themselves directly.
Thank you, hope this helps!
Jorge
I was hoping that there was a way to capture the probe traffic within the ACE.
Thanks anyway for your help, I will do the capture on the servers with wireshark.
Thanks!
Fernando
Fernando,
Good luck!
Jorge
Jorge,
How can I verify in the capture if the HTTP server is giving the correct answer
to the ACE? (or the answer the ACE expects to mark the probe as SUCCESS)
thanks,
Fernando
ACE is going to try to access: https://10.31.1.210/default.htm and wait for a 200 OK.
Jorge
Cesar Roque
Level 4
Level 4
Hi Fernando,
  interval 20
Cesar R
ANS Team
ajayku2
If it is not in production or if you dont have much load.
You can try playing with few of the debug option:
debug hm errors
debug hm events
debug hm info
The above will help you to identify the errors.
Also refer:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_Troubleshooting_ACE_Health_Monitoring#Troubleshooting_an_HTTPS_Probe_Error
regards,
Ajay Kumar
