ACE30 - PING to VIP and Client side SVI not working
sgonsalv
Hi Guys,
Having setup the ACE30 based on the configuration guides, I've been able to get basic load balancing working, probes, stickness etc.  However in testing connectivty, I've noticed that from the real server on the backend I cannot seem to PING:
1. The VIP for the web service that the server is a part of
2. The Client side SVI
I'd like this to work to ensure full connectivity.
I've applied ACLs to the Client side SVI (on the ACE) to allow this in both directions, and also removed any ACLs attached to the client side SVI on the MSFC where the subnet is actually homed.  However I just cannot seem to PING the Client side SVI on the ACE, or the VIP.  Trying to understand if this is normal behavior.
Have inserted my config below for completeness.
ACE30 Config
login timeout 60
hostname ACE1
boot system image:c6ace-t1k9-mz.A90_6_3_5.bin
boot system image:c6ace-t1k9-mz.A4_1_0.bin
resource-class RC_1
  limit-resource all minimum 10.00 maximum unlimited
access-list all line 8 extended permit ip any any
access-list v6-any line 8 extended permit ip anyv6 anyv6
class-map type management match-any REMOTE_ACCESS
  description Remote access traffic match
  2 match protocol telnet any
  3 match protocol ssh any
  4 match protocol icmp any
  5 match protocol https any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
interface vlan 768
  description Management connectivity
  ip address 10.20.40.72 255.255.255.0
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.20.40.254
context VC_1
  allocate-interface vlan 11
  allocate-interface vlan 186
  member RC_1
username admin password 5 $1$STizNv5q$i96.Qrt4C4SfHkbLyVT74.  role Admin domain default-domain
username www password 5 $1$ZAn8bOtv$xmmNlH8akF6iYfXdQCKMo1  role Admin domain default-domain
ssh key rsa1 1024 force
! VC_1
ACE1/VC_1# sh run
probe http HTTP_PROBE1
  interval 15
  passdetect interval 60
  expect status 200 200
  open 1
rserver host RS_MONASH_WEB1
  description Test Monash Web Server 1
  ip address 10.194.27.177
  inservice
serverfarm host SF_MONASH_WEB
  probe HTTP_PROBE1
  rserver RS_MONASH_WEB1 80
    inservice
sticky ip-netmask 255.255.255.255 address source STICKY_MONASH_WEB
  timeout 3600
  serverfarm SF_MONASH_WEB
  2 match protocol ssh any
  3 match protocol telnet any
class-map match-all VS_MONASH_WEB
  2 match virtual-address 10.194.11.1 tcp eq www
access-list ALLOW_TRAFFIC_TOWARDS_ACE extended permit ip any any
access-list ALLOW_TRAFFIC_TOWARDS_ACE extended permit icmp any any
  class REMOTE_ACCESS
    permit
policy-map type loadbalance first-match PM_MONASH_WEB_LB
  class class-default
    sticky-serverfarm STICKY_MONASH_WEB
policy-map multi-match PM_MULTI_MATCH_CLIENT_VIP
  class VS_MONASH_WEB
    loadbalance vip inservice
    loadbalance policy PM_MONASH_WEB_LB
interface vlan 11
  description Client connectivity on Vlan 11
  ip address 10.194.11.250 255.255.255.0
  access-group input ALLOW_TRAFFIC_TOWARDS_ACE
  access-group out ALLOW_TRAFFIC_TOWARDS_ACE       ! not sure if this is required as well?
  service-policy input PM_MULTI_MATCH_CLIENT_VIP
  no shutdown
interface vlan 186
  description CSM www monash
  ip address 10.194.27.189 255.255.255.240
  access-group input ALLOW_TRAFFIC_TOWARDS_ACE    ! not sure if this is required?
  access-group out ALLOW_TRAFFIC_TOWARDS_ACE      ! not sure if this is required?
  ip dhcp relay server 130.194.15.17
  ip dhcp relay enable
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.194.11.254
6500s
! test-clay1-gw - ACE connects to this 6500
svclc multiple-vlan-interfaces
svclc module 2 vlan-group 2
svclc vlan-group 2  11,171-499,768
! test-clay0-gw - Where Client side subnet, VLAN11 is homed
interface Vlan11
description Testlab server subnet
ip address 10.194.11.253 255.255.255.0
no shut
ip route 10.194.27.176 255.255.255.240 10.194.11.250
thanks
Sheldon
Marko Leopold
To ping your VIP of the webserver, you should apple the service-policy input command on VLAN 186 too. Currently the VIP only listens on VLAN 11. For the SVI i think that was forbidden by security reason, but i cant remember anymore. Maybe you just need to put the management policy on the interface VLAN 186. If it dont work, then my first guess was right
