another Sticky issue
benediktsv
Hi all
Ok - so we are running a ACE30 - and this is a site we are pushing out.
  • running SSL offloading for HTTPS
  • redirecting http -> https
  • ASP.net framework - that has a 20 minute sliding session time
  • ASP.net that need the session to stay on the same server.
Here is something that worries me:
ACE30Number1/WEB# show resource usage
        Resource         Current       Peak        Min        Max       Denied
  sticky                   419428     419428     419428     419428          0
Problem:
  • Stickyness is not working. - we are still mapping this out - it's somewhat working.
Question:
  • Are we doing it correct ? using a IP timeout ? what should we do ?
  • is the timeout of the sticky sliding ? or just a hard timeout ?
  • do we have an issue with sticky resource allocation ? (ANM shows global avalable 10, used 10, guaranties 10)
Here is a config exerpt
serverfarm host WWW.XXXX.COM_HTTPS
  predictor leastconns
  probe HTTP-ACTIVITY9999
  rserver LHR-XXXX 4443
    inservice
    inservice
class-map match-any VIP_XXXX.COM_HTTP
  2 match virtual-address YY.YY.YY.YY tcp eq www
class-map match-any VIP_XXXX.COM_HTTPS
  2 match virtual-address YY.YY.YY.YY tcp eq https
sticky ip-netmask 255.255.255.255 address source STICKY-WWW.XXXX.COM_HTTPS
  serverfarm WWW.XXXX.COM_HTTPS
  timeout 3600
sticky ip-netmask 255.255.255.255 address source FORUMS.XXXX.COM
  serverfarm FORUMS.XXXX.COM
  timeout 3600
class-map type http loadbalance match-any L7_SECURE.XXXX.COM
  2 match http header Host header-value "secure.XXXX.com"
class-map type http loadbalance match-any L7_WWW.XXXX.COM
  2 match http header Host header-value "www.XXXX.com"
policy-map type loadbalance first-match POLICY_XXXX.COM.HTTP
  class L7_WWW.XXXX.COM
  class L7_FORUMS.XXXX.COM
    serverfarm RE_forums.XXXX.com
  class L7_SECURE.XXXX.COM
    serverfarm RE_secure.XXXX.com
  class class-default
policy-map type loadbalance first-match POLICY_XXXX.COM.HTTPS
    sticky-serverfarm STICKY-WWW.XXXX.COM_HTTPS
    sticky-serverfarm FORUMS.XXXX.COM
    serverfarm SECURE.XXXX.COM.HTTPS
  class class-default
policy-map multi-match WEBCLUSTER
class VIP_XXXX.COM_HTTP
    loadbalance vip inservice
    loadbalance policy POLICY_XXXX.COM.HTTP
    loadbalance vip icmp-reply active
  class VIP_XXXX.COM_HTTPS
    loadbalance policy POLICY_XXXX.COM.HTTPS
    appl-parameter http advanced-options YYTT
    ssl-proxy server XXXX.COM
- Benni
ajayku2
See if your symptoms are similar:
Look at the output of "show sticky databse group Cookie_Sticky"
If you see lot of entry with a time-to-expire value of zero. Then the command "
timeout activeconns" will help you to reduce the number of entry.
The way it works is this: after one connection is open and the sticky entry for that connection is created, the timeout will immediatly start decreasing. Once it reaches 0, if there are still active connections for that sticky entry, the entry won't be deleted unless the "timeout activeconns" option within the sticky group is enabled. If no active conns are present for that sticky entry, the entry will be freed.
For reference :
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_2_0/configuration/slb/guide/sticky.pdf
read section
Enabling an IP Address Sticky Timeout to Override Active Connections
regards,
Ajay Kumar
Should we use IP based sticky for normal ASPnet web ?
does the IP sticky relate to the HTTP session in any way ?
I'm trying to understand how and what would be the best way to configure this + I'm trying to figure out if I'm depleating the sticky resource and thus the ACE is prematurly deleting the entires / not creating new sticky sessions.
It depends on the app and the way you have set your network.
No, As IP based sticky is based on IP. HTTP does not come into picture.
Also FYI:
Once the database fills up, the following logic is performed to determine which entry to steal to make room for the new sticky entry:
- Find an entry with no active-conns that has timed out. - Find the entry with no active-conns that has not yet timed out. - Find an entry with active conns. The final two contribute to the "Total sticky entries reused prior to expiry" count. Note that a new sticky entry will ALWAYS be created, there are never any denies for new sticky entries.
Hope that helps.
regards,
Ajay Kumar
