ASK THE EXPERTS - WAAS MONITORING AND REPORTING
ciscomoderator
Community Manager
Community Manager
Welcome to the Cisco Networking  Professionals Ask the Expert conversation. This is an opportunity to learn about Cisco Wide Area Application Services monitoring and reporting with Michael Holloway and Joe Merrill.  Michael is an escalation support engineer in the Application  Delivery Business Unit focusing on escalations to engineering related to  the Cisco Wide Area Application Services (WAAS) product. He has worked  with Cisco WAAS since its initial development, and with the first  product beta.
Joe Merrill is an escalation support engineer in the Application Delivery Business Unit focusing on escalations to engineering related to the Cisco Wide Area Application Services (WAAS) product. He has worked with Cisco WAAS since its initial development, and with the first product beta.
Remember to use the rating system to let Michael and Joe know if you have received an adequate response.
Michael and Joe might not be able to answer each question due to the volume expected   during this event. Our moderators will post many of the unanswered   questions in other discussion forums shortly after the event. This  event  lasts through August 27, 2010. Visit this forum often to view  responses  to your questions and the questions of other community  members.
24 Replies 24
I need the explanation of the below terms.
1)When we pull bandwidth Optimization report, on Y-Axis the graphs says Effective Capacity .What is Effective Capacity?
2)what is reduction % excluding and including passthrough
3)What is effectivity capacity including and excluding passthrough ?
4)With the help of which report, we can show the customer that the file download which took 10 mins in first attempt, is downloaded in 10secons in next attempt?
5)How to show that the bandwidth utilization has decreased by which %.
6)Which report says that the applications have become this much time faster?
These questions are normally put forwarded by many customers ? Can you please help me with your expertise answer ?
Vijay
Very good questions. Let me try and take them one at a time. Some of the answers you will likely find in the CM GUI help (upper-left corner is the Help button), or in the online documentation. But let's add a little more color and detail.
Basically, the "effective increased bandwidth capacity" is telling you how much additional WAN bandwidth you've gained because of the optimization. It will chart somewhere between 1 times and 100 times. Typically it charts all traffic, though you can configure it to chart traffic for specific Applications.
The CDM online help gives the formulas used to chart the graph:
Effective WAN Capacity = 1 / (1-% Reduction Excluding Pass-Through)
% Reduction Excluding Pass-Through = (Original Excluding Pass-Through - Optimized) / (Original Excluding Pass-Through)
Looking at the formulas given above might help you understand. The one is a reduction ratio compared to only the original traffic that is optimized. The other is a reduction ratio compared to all original traffic, whether it is optimized or not. So, if you want to know what kind of optimization you are getting for the traffic that you configured to have optimized, look at the "excluding pass-through" numbers. If you want to know the positive effect that optimization is having on your full traffic load, take a look at the "including pass-through" numbers.
The effective capacity is what kind of throughput you can potentially realize on the WAN -- assuming you would fill it to 100% capacity -- because of the level of optimization you are seeing. The "including" numbers show you the effect of optimization compared to all the traffic passing through the WAE whether it is optimized or not. The "excluding" numbers show the effect of optimization compared only to the traffic that is receiving optimizations.
This one is a little trickier. The reports are much broader than a single connection. They are for all traffic, or for traffic that matches specific defined Applications. You could create a separate Application and matching classifiers for the client and/or server IP addresses and/or ports, run the test, then configure the charts to only show you the data for that Application. By default, statistics for an Application aren’t charted unless you check the "Enable Statistics" box when defining/editing the Application.
You want to look at the % reduction numbers you asked about in #2 above.
This is probably the hardest question to answer.
"Faster" isn't always easy to define. You are probably talking about user experience rather than statistics found in a network device. What determines that experience? A web page fully populating with all the pictures? A CIFS-based application that saves a file? A custom application that collects data from different servers over different protocols to perform some operation? Much of that is subjective and based on multiple individual requests, sometimes over different protocols.
What we can provide are statistics to show the effect of WAN optimization and application acceleration for specific types of traffic. We can't show you that displaying a web page is N times faster with WAAS, because we don't know which of all the many HTTP requests that are made are specific to the user experience. But we can show that each of the requests received so much overall optimization, so much optimization from DRE, so much optimization from LZ, so much added benefit from HTTP acceleration.
What you would probably do is collect some base-line timings for performing certain user activities, then perform the same operations both cold (first pass) and warm (subsequent passes). Back up those timing numbers with reports from the CM GUI, and perhaps even the "show statistics connection connection-id ". Which reports to use? Start with those Optimization and Acceleration reports. Those are the reports we expect will give the most complete/accurate pictures of the benefit of WAAS. You can also create and even schedule custom reports as needed.
Hi Joseph,
Thanks very much for the detailed answer.Much Appreciated.
We are going to integrate NetQoS RA with WAAS.It would be new to me.Can you just give a briefing regarding this integration or help me with the link to documentation stuff pertaining to this.
Vijay
Essentially you will enable the FlowAgent feature on your WAE and point it at your NetQoS SuperAgent monitoring agent console device. The FlowAgent feature will collect statistics and send them over to the NetQoS SuperAgent. You can then use NetQoS to present that data in various ways, such as a chart showing bandwidth usage.
Enabling the FlowAgent on the WAE can be done either from the CM GUI device or device group configuration page, or from the CLI itself. The procedure is really two simple configuration lines. It looks like this from the CLI...
flow monitor tcpstat-v1 host
flow monitor tcpstat-v1 enable
You will need to follow the documentation for your NetQoS device in order to configure it as desired.
The Configuration Guide for WAAS 4.2.1 provides the basic instructions for configuring the FlowAgent on Cisco WAAS:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v421/configuration/guide/monitor.html#wpmkr1163525
This white paper may also be helpful:
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/prod_white_paper0900aecd80693006.html
Hi Michael and Joe!
How are you?
I upgraded a WAVE-574 with the last WAAS version 4.2.3.
But, I am getting a alarm of "Memory Mismatch" (see the attachment).
My WAVE-574 has 4GB of RAM.
Do I think the version 4.2.3 is checking if WAVE-574 has 3GB or 6GB of RAM, right?
I downgrade it to version 4.1.7 and I didn´t get any problem.
Do you think CISCO will send a new release to fix that?
Rodrigo Marchina Soares
The WAVE-574 device supports either 3 GB or 6 GB or RAM.  WAAS software expects one of those two configurations, and will allocate disk and memory for the optimizers and accelerators based on one of those two configurations.  With an unsupported configuration of 4 GB, there is a risk of unpredictable issues as maybe not enough memory would be allocated for the configured disk space.
This should have been caught in 4.1.7.  It is a good thing that we are catching it in 4.2.3.
Look for bad DRAM that dropped the discovered memory from 6 GB installed to 4 GB, and request RMA as needed.
mario-leitao
Level 4
Level 4
I installed Waas Mobile but I want to configure the server´s address on the client software distribution package as its hostname instead of its ip address. Is it possible? In the waas mobile 3.5.1 admin manual (page 34) it says that I can configure as server ip or hostname but when I try to configure it then I just get a drop down list with the server ip address. The point of this configuration is that I have a customer that needs to access the waas mobile server via its Name because it will access from different locations and via its ip address is not a viable solution.
That drop-down list also contains a blank line as the first line in the list.  If you click that blank line, you are then given the opportunity to enter either a hostname or IP address.  But whatever you enter must be resolvable.  It is this hostname or IP address that a client will use when it is first installed and contacts the management server in order to determine which server the client will then use for acceleration.
kumar_vijay
Recently we upgraded the IOS of some 20 WAAS-574-WAVE devices from 4.1.7 to 4.2.1 .For all devices upgradation was following with the same process.
Here is what happened after reebot :
1)14 devices came up smoothly.
2)6 boxes were continusly rebooting.
3)We were able to recover 3 boxes with rescue CD.
4)1 boxes came up after hardbooting 3-4 times.
5)2 boxes didn't come up by any means and hardware had to be replaced.
Any idea what could be the reasons behind it ? The same method was followed for all devices and are of same model.
Vijay
I'm afraid that without looking at data from the failed devices, it would not be possible to speculate on the causes. There are many possibilities ranging from various hardware failures to software problems. Likely we will find that not all failures occurred for the same reason.
In my experience, such a concentration of failed upgrades is not common and needs to be investigated. If you have not already done so, please involve TAC to collect data from the failed devices and have it analyzed for individual failures on each device as well as holistically to see whether there could be a common cause.
