Certificate validation check with HTTPS probes
yves.haemmerli
Level 5
Level 5
While configuring an HTTPS probe I observe that if the certificate on the target server is expired, the ACE marks the server as PROBE-FAILED. A Wireshark trace shows that the ACE refuses an expired certificate. Here is the probe configuration :
probe https NCL_PROBE_HTTPS
description *** Server Health Probe ***
interval 5
faildetect 2
passdetect interval 5
passdetect count 2
receive 4
ssl version all
request method get url /monitor/
expect status 200 200
header User-Agent header-value "Cisco ACE-4710"
open 2
expect regex "PROBE_OK"
I can disable the expiration date validation check with an ssl parameter-map, but such a map is only applicable to the backend session (on a ssl-proxy service), but not on a https probe...
How do I make sure that my https probe can bypass the certificate validation check ?
Thank you for any help
Yves Haemmerli
With ACE 1.x code this probe wouldn't have failed.
With ACE 2.x code, https probe check the validity of the certificate
send by server.
I don't think there is a way to change this behavior.
Syed Iftekhar Ahmed
send by server.
Syed Iftekhar Ahmed
Thanks again Syed
Yves
